Trouble setting discharge and charge
zingfharn
So I'm at a bit of a loss. This is sort of app related and sort of just general help.
For background, I'm on octopus flux export.
I tested the basic "force time charge", and it worked great (to charge my battery off peak). I have a 9kw inverter, and in 90 mins, it charged at 13kwH, so pretty awesome results.
I then switched it off, and tested the mode scheduler to force discharge to the grid between 4 and 6pm, which also worked great, although I had to do this through the website, because the app mode scheduler appears totally broken. It pushed out 12 kwH at 6 per hour for 2 hours, so again, great result.
When I tried to combine these, I kept getting weird errors, but I guess it's just either basic "force time charge" or "mode scheduler", which is fine. However...
I set forced charge in the mode scheduler on the website last night, and instead of charging, it discharged (see attachment)
I've been playing around with different settings this morning, and while I've managed to get the battery to charge a bit from the grid, I can't seem to get it to charge at max like it does from the basic "force time charge"
What settings do I need to enable the mode scheduler to force charge at max capacity please?
I’m assuming you have a KH9 ?, the first thing to say is to get your firmware updated to the latest version if you haven’t already as there have been a number of changes and bug fixes with this being such a new inverter.
The app scheduler is having problems at the moment as Fox have added the ability to schedule a force charge to a specific MaxSoC - the problem being that only the very latest firmware for the H1 works with this, which means you have to set it on either the V1 app, the website or using Energy Stats. There have been a number of releases which profess to fix the app, but i’m still hearing some people report it doesn’t work for them.
You are correct in that you cannot use the older charge periods at the same time as the scheduler - it is one or the other. If you try and set a charge period when a schedule is set you’ll get an error in the app.
The scheduler force charge and the old charge period ‘should’ be the same but they measure the load and charge differently so there are small differences of charge rate between them - earlier firmware versions didn’t allow scheduled force charge to use solar power in combination with grid either but that has been corrected on latest firmware.
The scheduler for force charge only needs the time set and minSoC, FDSoC and FDpwr are ignored but they must be set to the defaults of 10,10 and 0 - if it gives you the maxSoC option set it to 100.
Personally I don’t use the scheduler for anything, I use the old charge periods as they ‘just work’ - plus if there is a cloud outage (not unknown for Fox), you can set or unset charge periods through the inverter menus, you cannot do that with the scheduler once running it is locked in unless you have cloud access to disable.
So I think to summarise make sure you have the latest version of firmware, and where at all possible use the older ‘charge periods’ with charge from grid enabled.
zingfharn
Thank you so much for this!
I do have a KH9. I've emailed support to see if I'm on the latest firmware (currently: Master : 1.29, Slave : 1.01, Manager : 1.21, but no idea how to check if that's latest myself)
I don't see a MaxSOC option anywhere on the website, and energy stats tends to time out a lot (and also doesn't have a maxsoc setting that I can see).
I think the issue is that when I leave MinSOC, FDSoC and FDPwr at 10/10/0 with "Force Charge", the battery just force discharges. I've played around with setting those values to 100 and the FDPwr to 7000, and it starts charging, but only at very low levels (like 1500).
I would love to just use the old charge periods but the main reason I have a big battery is to dump back to the grid at peak, thereby earning money (charge a little offpeak, fill the rest from panels during the day, dump most at peak, repeat).
If I'm not discharging at peak, then I have enough charge to see me through the night (and I'm not taking advantage of flux, which helps offset the cost of the install).
The latest is -
Master 1.34
Manager 1.28
I’m pretty sure that getting this updated will resolve your force charge power problems 👍
elvisparsley
Did you ever solve this. I have exactly the same issue
My inverter is a KH7
version master 1.27
version slave 1.01
version_arm 1.19
I have an 10kw ep11 battery
bms version 1.002
elvisparsley wrote: Sun Sep 08, 2024 10:06 pm Did you ever solve this. I have exactly the same issue
version master 1.27
version slave 1.01
version_arm 1.19
bms version 1.002
Your firmware versions are old now, speak to your installer or email Fox service to get them updated - that will resolve it.
Mark-Averill
Some of you have made reference to updating the settings on the website, I have looked on the foxesscloud but can’t see anywhere to update settings, could you point me in the right direction please?
BMS: HV2600 v2 version 1.013
Inverter: H1-3.7-E. Version (where do I find that?)
Battery: 3x HV2600 v2 version 1.13
Mark-Averill wrote: Tue Sep 10, 2024 12:26 pm Some of you have made reference to updating the settings on the website, I have looked on the foxesscloud but can’t see anywhere to update settings, could you point me in the right direction please?
On the website go to the Inverter details page (the one that shows ‘Energy Flow’), then click on the red box in the red circle if you want normal battery charge periods, or the blue icon in the yellow circle if you want scheduler
Mark-Averill
Fabulous, found that! I am prompted for a password when trying to access the scheduler… is there a standard password or will it be buried somewhere in the inverter settings menu?
Mark-Averill wrote: Tue Sep 10, 2024 2:40 pm Fabulous, found that! I am prompted for a password when trying to access the scheduler… is there a standard password or will it be buried somewhere in the inverter settings menu?
In all honesty i've never known it to ask for a password when you click that but I do have an agent account so maybe it's different for users - it's got to be either your password to enter 'settings' normally '0000' or the password you log in with.
reef
That's odd. It has never asked me for a password either and I don't have an agent account!
Mark-Averill
For completeness, it was the same password as the log in password. Worked a treat, thank you
Mitch23232323
Hi all
Apologies if I’m in the wrong place. Just got solar with 10.5 battery. I want to charge it from the grid in cheap rate but no idea at all how to do this??
Any help appreciated
Mitch
Mitch23232323 wrote: Sun Oct 06, 2024 10:31 pm Hi all
Mitch
You should have been given credentials that will allow you to log in to either the Fox ESS app or the FoxESSCloud website - Of the 2 apps I would recommend you download the V2 app.
Then when you have logged in, click on 'Quick Settings Here', then click on 'Charging Time' and set one of the time periods to suit your charge times, note if your low tariff spans midnight you have to use 1 charge period up to midnight 23:30-23:59 and the other after midnight 00:00-05:30 - make sure that Charge from Grid enabled is on - and that when you view them in the settings that the slider is on to show they are enabled.
Bozerboy
Octopus flux best import rate 0200-0500 hrs. Managed to set this on fox cloud2 app. But no idea/ cannot find how and when batteries can export.
Can someone explain in easy terms
