You’ve had better weather than me today, grey and overcast here
This is your trace to date, which confirms what you have said - Fox1 Load is their cloud totals (wrong), load_daily is the sum of your measured load power (correct), and ct2_daily the sum of the CT2 power sensor.
I’ve emailed FoxESS in China to ask them to review the load totals problem, it usually takes a couple of days for them to reply, sometimes longer if it’s complex when lots of different teams are involved, i’ll keep my fingers crossed and let you know when I hear something.
Load Power
(a little bit) of an update, Foxess are definitely looking at it, i've swapped a couple of emails with the product manager in China over the last few days with additional information requests.
FYI - I've been swapping emails almost daily, they seem to be struggling with the concept that the cumulative load figure is incorrect, despite the fact it patently is.. if you don't mind i've shared your SN with them so they can look at 'real' data - but after the api outages yesterday I suspect they may be busy today
Yes, no problem.
The API is down again now too
Funnily enough I raised a ticket on Friday to get my batteries and BMS onto the latest firmware (HV25s still on 1.004 master and 1.00 (x4) and 1.01 (x1) slave) and I'm still waiting on a response to that too.
Hi, bit of an update for you - but easier for me to explain by email - i'll ping one across to you shortly.
I think this is the option that Al added for H3 users where the meter2 signal is inverted and suppresses the load power - you should see your load power report correctly with this (using a formula) but sadly the ‘load yield’ has to be fixed in the cloud.
Yes, that's what I'm seeing.
Re: the cloud. Fox seem to have a bit of backlog on tickets at the moment, sorting my battery firmware update yesterday (ticket is from 1st March), so perhaps there will be an update next week, fingers crossed.
