Re: Grid Pressure/Push back Setting added to the K and H1-gen2
I have two KH10.5 inverters.
Does the Grid Pressure/Push back setting have to be the same on both, or is it sufficient to simply change it on the Master inverter?
Good result all the same.
2 x KH & 1 x H1
Dave Foster wrote: Wed Feb 12, 2025 8:13 pm It’s not available through the inverter menu’s, only an installer level account can access this remotely.
I've just found this in the v2 of the web site
https://www.foxesscloud.com/v2/login
Devices / Select Inverter / Device Details / Settings / BasicParameters2 / MeterCompensation
I set to -50, octopus real time app shows -30, so it's about 20W out.
great result, thanks for sharing the update.
2 x KH & 1 x H1
Chapeau wrote: Mon Jun 23, 2025 7:08 am I set to -50, octopus real time app shows -30, so it's about 20W out.
Just had my firmware updated and now the PV's lower than usage I can test it. Set mine at -30 based on the above and I'm hovering between -6W and -11W, so similar results.
