I have two KH10.5 inverters.
Does the Grid Pressure/Push back setting have to be the same on both, or is it sufficient to simply change it on the Master inverter?
Good result all the same.
I've just found this in the v2 of the web siteDave Foster wrote: ↑Wed Feb 12, 2025 8:13 pm It’s not available through the inverter menu’s, only an installer level account can access this remotely.
Devices / Select Inverter / Device Details / Settings / BasicParameters2 / MeterCompensation
I set to -50, octopus real time app shows -30, so it's about 20W out.
great result, thanks for sharing the update.
How do I know if I have an H1 Gen1 or Gen2?
I have a H1-3.7-E now on manager version 1.78 and master version 1.63 but can’t see this new option.
If you are on those firmware versions you will have an H1 Gen 1 and sadly those settings have not yet been added, it's only on the later models (so far)
That’s annoying as presumably there is not technical reason they couldn’t enable setting this on the older inverters.Dave Foster wrote: ↑Wed Jul 16, 2025 4:34 pmIf you are on those firmware versions you will have an H1 Gen 1 and sadly those settings have not yet been added, it's only on the later models (so far)
I’ll have to wait and hope they add it.
Thanks for the reply.
Hi Will and the wider FoxESS Community,
This has been a great thread for me as a newbie to solar. There's been lots of useful info regarding pushing back on the grid, so thanks.
I've currently got a 14 to 20W draw according to my Octopus Mini device that I'm keen to push back. I've got old firmware in my KH8 (M=1.39, S=1.01, ARM=1.35). It seems as though dropping a request to Fox support seems like the path of least resistance to getting that updated. I'm also keen to set up the forced discharge of my batteries at the peak export rates which, again, needs the later firmware.
However, before updating, I see that on Will's really useful firmware spreadsheet that the latest Manager v1.45 firmware has a note saying there's issues with the charge scheduler manager. I'd like some advice/thoughts on whether I'm best off waiting for a fix in the Master v1.45, or are the issues insignificant enough not to warrant holding back on the other 2 advantages?
I'm not looking to hold anyone to account - just wanting to avoid resolving one thing and breaking something else!
Thanks,
James S.
Thanks,
James S.
Upgrade to v1.43 of manager and latest on slave and master and you'll be fine. Once updated you will need your installer or fox to set a negative number in the meter compensation box. I'd recommend -25 as a starting point
Fab. Thanks Will for the quick reply.
James S.
James S.
Actually, with Fox Cloud v2 you can set this yourself. Hmm, let's see if I can find it now...
On the web go to: https://www.foxesscloud.com/v2/login
Login with your usual Fox Cloud / App username and password.
Click on DEVICES, then on your Inverter.
Click on SETTINGS
BasicParameters2
MeterCompensation
Set what you want then click the right arrow button to the right of it
Click on SETTINGS
BasicParameters2
MeterCompensation
Thanks for this video and discussion, I just had my kit installed and noticed Octopus was reporting a 40w idle import. I've tweaked MeterCompensation within BasicParameters2 from 0 to -40 to swing this as a continual export (where applicable).
I can see the setting on the v2 dashboard but can't change anything. Does this still need to be the installer?
It worked for me. I'm not an installer, have a normal customer account I think.
So glad i came across this! I can confirm this works, because i was worried i was going to have to go back to the installer and they have been a PITA to deal with. I've had so many issues with my install and their after sales support is almost non existant! Might be worth noting that the first time logging into the V2 cloud portal, you might have to also manually add the interview via the serial number before the rest of the system pops up in the devices.UK_KH_User123 wrote: ↑Mon Aug 04, 2025 8:34 pm Actually, with Fox Cloud v2 you can set this yourself. Hmm, let's see if I can find it now...
Click on SETTINGS
BasicParameters2
MeterCompensation
Brilliant thread, took me a while to find correct location when I opened Fox Cloud v2 but got there in the end.
Thanks all for the assistance.
FoxESS AC1-5.0-E1-G2 Inverter & EP11 battery
25.34m2 Philadelphia Solar 4.0kWp max output
BYD Dolphin Design & 7kW Zappi charger
Vaillant 10kW AroTHERM Heatpump & UFH
Thanks, @UK_KH_User123. I had seen the video a few weeks ago, but couldn't find how to access the settings in FoxCloud. I've set mine to -20 for now and see how it goes.UK_KH_User123 wrote: ↑Mon Aug 04, 2025 8:34 pm Actually, with Fox Cloud v2 you can set this yourself. Hmm, let's see if I can find it now...
Click on SETTINGS
BasicParameters2
MeterCompensation
Fenny
After finding this post yesterday, logged in to FoxCloud 2.0, and found the meter compensation and adjusted. However, this morning when I have logged in, the "Settings" tab has gone .. and not able to go back in to adjust
Any ideas why it has now disappeared?
Same here, must be a Fox change, maybe an update?
tbh it was always an installer setting, it's just the V2 website didn't implement access properly - it looks like that might now be the case which means only an installer/agent can make those changes.
Oh great .. just when got it working .. and they remove. Looks like I did set the MeterCompensation to the right level though ... as not importing anymore
I think they were also giving access to the G100 settings as well which is a big no-no. So not surprised it's been locked down.
Hopefully they'll create a sanitised page for user level settings, and include meter compensation in it.
Well .. glad I got in there before they closed it off .. and was able to set my own MeterCompensation .. which I set it for -35 or -40 .. which feels about right
