Unable to set export limit on STAR-H3-12.0-E
On the inverter itself I tried to set the ExportLimit under Grid-Settings to 4000W and the display shows "Success", but does not save the setting.
I followed the Youtube video, entered the passcode, went to Grid -> ExportLimit and then used the enter keys and up/down to enter 4000W, confirmed and got the message "Success" and below an "Exit". When I click on Esc, I return to the ExportLimit mask and when I exit all the way and go back in, the ExportLimit is at "000000W". When I do not exit the "Success" screen after entering "0004000W", eventually the inverter goes to the home-screen and then checking it again it is back to "0".
What is wrong here?
Version_Master:2.11 / Version_Slave:1.03 / Version_ARM:1.85
Side question: How do I restart the inverter - the On/Off switch below the Inverter does not seem to do anything. The "Off" switch in the middle (see images here: viewtopic.php?p=7838#p7838) turns off the electricity entirely.
🏡 System Setup (Austria): Inverter: STAR-H3-12.0-E / Battery: STAR EP11 (10.36 kWh) / Panels: 24x Canadian HiHero 440 Wp (10.56 kWp total)
Re: Unable to set export limit on STAR-H3-12.0-E
might be easiler to ask your installer to set the limit using the cloud portal for installers.
Will wrote: Wed May 28, 2025 6:52 pm might be easiler to ask your installer to set the limit using the cloud portal for installers.
My installer is highly unreliable and not very pro-active. It would take several days to organise this, but in the mean-time I found in the new Cloud platform, that I can manually adjust it via the device settings.
What is this new cloud platform?
Will wrote: Thu May 29, 2025 11:28 am What is this new cloud platform?
Via https://www.foxesscloud.com/v2/plants/plant you can configure settings on the inverter:
Oh the beta platform, they've not yet locked it down then :) good find
Will wrote: Mon Jun 02, 2025 5:00 pm Oh the beta platform, they've not yet locked it down then :) good find
I do hope that in the beta-platform users can do basic settings. As I said, my installer took now 5 days to respond to provide a setting change. This makes it impossible as an enduser to operate the device. I do not want full control, but i should be able to set export/import limits. (FWIW: My installer decided in the Peakshaving config to setup a 40000W import limit without notifying me - something I just found in the beta settings, otherwise I would have happily imported electricity).
yeh, I've suggested Fox make settings available via accepting a "I know what I'm doing" disclaimer. they've taken it under review to the product team.
Will wrote: Mon Jun 02, 2025 6:57 pm yeh, I've suggested Fox make settings available via accepting a "I know what I'm doing" disclaimer. they've taken it under review to the product team.
Thank you. I suppose there is no way end-users can vote for such features?
