FoxESS Support (25/10/2023) advised that the latest firmware versions for my H1/AC1 (Model H1-3.7-E) inverter were:
- Manager: 1.70
- Master: 1.63
- Slave: 1.02
Requested they updated the software via a Ticket on the FoxESS Support website with "Fault Classification = none".
My inverter came with:
Master version 1.48
Slave version 1.02
Manager version 1.50
Hope this helps others.
H1-3.7-E Latest Firmware versions (25 October 2023)
- Grey.Forums
9xLongi LR5-54HTB-430M panels
H1-3.7-E
3xHV2600
Zappi 2H07TB car charger
H1-3.7-E
3xHV2600
Did you manage to have the Force Discharge Function on your system?
Mine is
Master: 1.63
Slave: 1.02
Manager: 1.68
but the Force Discharge template is not showing up.
Mine is
Master: 1.63
Slave: 1.02
Manager: 1.68
Kind regards,
Lessa
H1-3.7-E
ECS2900-2 with four slaves
11 Jinko Tiger Neo 420W (4.62kWp)
5x TIGO Optimisers due to three roof distribution
Lessa
H1-3.7-E
Manager 1.68 provided schedules, but if you want force discharge you need Manager 1.70
raise a ticket or send an email to FoxESS support and ask for your inverter Manager to be upgraded to 1.70 (the rest of your module versions are upto date and correct)
Hi Dave, is there a repository webpage where we can check the firmware versions while been an end-user?Dave Foster wrote: Wed Feb 21, 2024 8:03 pm Manager 1.68 provided schedules, but if you want force discharge you need Manager 1.70
For example:
H1-3.7-E
Master: 1.63
Slave: 1.02
ARM: 1.70
ECS2900-2
BMS: 1.005
I believe that the ECS2900-2 is outdated, I have seen some posts around it. Is there a version control webpage where we can learn about the changes between the firmware?
Thanks in advance!
Kind regards,
Lessa
H1-3.7-E
Lessa
H1-3.7-E
Hi, unfortunately not (at the moment), we have asked Fox to allow users to request firmware updates when available but as yet there is no fixed date to provide that - for now just ask and someone with an agent account can look it up for you.lessa wrote: Wed Aug 14, 2024 1:43 pmHi Dave, is there a repository webpage where we can check the firmware versions while been an end-user?Dave Foster wrote: Wed Feb 21, 2024 8:03 pm Manager 1.68 provided schedules, but if you want force discharge you need Manager 1.70
For example:
H1-3.7-E
Master: 1.63
Slave: 1.02
ARM: 1.70
ECS2900-2
BMS: 1.005
Thanks in advance!
The latest versions for your H1 inverter are -
Master 1.65
ARM(Manager) 1.74
And for your batteries - ECS2900-2
BMS (Master) 1.014
Battery (Slave) 1.11
Either your installer can do it remotely, or if you email Fox service with your inverter serial number and ask for your inverter or battery firmware (or both) to be updated.
Thank you very much for checking this again Dave!
I will raise a support ticket.
Hopefully they will make a repository webpage with the changes soon, unfortunately my installer is not so proactive to routinately check their customer installed base and make the updates.
Thanks again
Thanks again
Kind regards,
Lessa
H1-3.7-E
Lessa
H1-3.7-E
To keep the threat updated, my last request (30/08/2024) generated the following versions:
For the inverter
For the inverter
- Master 1.65
ARM(Manager) 1.74
- BMS (Master) 1.016
Battery (Slave) 1.12
Kind regards,
Lessa
H1-3.7-E
Lessa
H1-3.7-E
Hi Dave, would you be able to inform if this stills the current version? About 4.5 months since my last check in and I thought to come here to ask about it.
Did Fox created a webpage with the release notes of the firmware already? Or self-service upgrade pushes? So that we can check the changes and version before submitting tickets
Thanks in advance for sparing your time to help with this.
Dave Foster wrote: Wed Aug 14, 2024 6:02 pmHi, unfortunately not (at the moment), we have asked Fox to allow users to request firmware updates when available but as yet there is no fixed date to provide that - for now just ask and someone with an agent account can look it up for you.lessa wrote: Wed Aug 14, 2024 1:43 pmHi Dave, is there a repository webpage where we can check the firmware versions while been an end-user?Dave Foster wrote: Wed Feb 21, 2024 8:03 pm Manager 1.68 provided schedules, but if you want force discharge you need Manager 1.70
For example:
H1-3.7-E
Master: 1.63
Slave: 1.02
ARM: 1.70
ECS2900-2
BMS: 1.005
Thanks in advance!
Master 1.65
ARM(Manager) 1.74
BMS (Master) 1.014
Kind regards,
Lessa
H1-3.7-E
Lessa
H1-3.7-E
On the inverter the latest versions are Master 1.67, Manager 1.76 but the changes were minor (still no release notes i'm afraid) - I am still running on 1.65, 1.74 (working on the 'if it's not broke don't fix it principle').lessa wrote: Tue Feb 25, 2025 1:17 pm Hi Dave, would you be able to inform if this stills the current version? About 4.5 months since my last check in and I thought to come here to ask about it.
Master 1.65
ARM(Manager) 1.74
BMS (Master) 1.014
ECS battery firmware versions are unchanged.
Amen! An excellent principle! thank your for the quick turnaround Dave, if you remember, post a note about any interesting update
it will be really appreciated.
Dave Foster wrote: Tue Feb 25, 2025 1:29 pm On the inverter the latest versions are Master 1.67, Manager 1.76 but the changes were minor (still no release notes i'm afraid) - I am still running on 1.65, 1.74 (working on the 'if it's not broke don't fix it principle').
Kind regards,
Lessa
H1-3.7-E
Lessa
H1-3.7-E
