Everything was working fine until I got the versions below a short while ago - pushed out by either my installer or FoxESS without a request (this time!)
I now have the "No PV output/export when inverter is set to force charge mode and battery reaches or is at 100% during the scheduler period" issue which I believe has already been fixed on H1 Gen 1 inverters.
Can you advise if there's anything later than these please?
H1-5.0-E-G2 - Master : 1.23 Slave : 1.02 Manager : 1.38
Batteries - ECS2900-2 - Master 1.013 Slaves 1.10
Datalogger - W4 - 4.12
In the (continued but I believe promised?) absence of a FoxESS web support page with latest version and release notes perhaps a "sticky" post with a table all of the latest versions for each inverter and battery type would save you a load of individual requests?
Many thanks in advance,
Jim
Fox ESS H1-6.0-E-G2-WL Firmware - Master: 1.53 Slave: 1.04 Manager: 1.39 Datalogger (internal wifi) : 2.09
Fox ESS ESC 2900-H4 Cube Battery - Master plus 3 Slaves - All V2 - 11.52kWh Firmware - Master: 2.015 All Slaves : 1.150
Fox ESS Firmware updates applied March 2026
Octopus Intelligent Go tariff
Latest H1-G2 firmware has had a few updates, as usual there are no release notes - but with such a young product the latest versions are usually the best to be on.
Master 1.26, Manager 1.42 (Slave the same at 1.02)
Datalogger 4.13
Batteries ECS2900-2 Master 1.015, Slave 1.11
The latest battery firmware has changed the way residual power is reported, so rather than saying whats left in the battery it appears to be the maximum capacity the battery has when at 100% (like a state of health) - this hasn’t been confirmed by Fox, instead found by users but I would recommend holding off on updating them for a while until we know more (your current versions are stable).
The sticky page is a good idea, the only down side being the newer inverters H1-G2, KH and H3 Pro are changing regularly at them moment.
So thats a definite inverter upgrade required
Datalogger 4.13
Many thanks Dave - let's hope FoxEss catch up with their 2-day ticket response to the ticket I raised 3 days ago then
I also am interested in updated to the H1-5.0-E-G2 firmware. I'm currently unable to set a charging period for my ECS2900-2 battery set (master + 2 extra slaves) from either the front panel, web or phone app.
My firmware versions are:
Inverter :
Master : 1.18
Slave : 1.02
ARM : 1.28
Battery:
BMS : 1.006
I'm not sure which versions numbers are relevant. Many thanks.
Inverter :
Master : 1.18
Slave : 1.02
ARM : 1.28
Battery:
BMS : 1.006
These are quite old firmware versions, I would recommend you upgrade your inverter and battery to the latest version.mrussell42 wrote: ↑Sun Sep 01, 2024 4:35 pm Hi,
Inverter :
Master : 1.18
Slave : 1.02
ARM : 1.28
Battery:
BMS : 1.006
You can either ask your installer to do it, or email Fox UK service include your inverter serial number and ask them to update your inverter and your battery firmware.
I had all mine updated again within the last 10 days.
Current versions (installed as at as at 2/10/24) appear to be :
H1-5.0-E-G2 (Gen 2 inverter) - Master 1.27 Slave 1.02 Manager 1.44
ESS2900-2 (ver 2) Batteries - Master 1.016 Slaves 1.13
W4 (Datalogger) 4.13
FYI
Updated H1-5.0-E-G2 inverter today (5th Nov 2024).
Master 1.27
Slv 1.02
Manager 1.44
Master 1.27
Slv 1.02
Manager 1.44
Thanks but I've been on those since 2nd October - the Mode Scheduler bug still exists in those versions (PV output clipped when SoC reaches 100% as opposed to being used for house load and/or exported) - I went back to the "old" 2 force charge schedules for now......
Update - I added an extra ECS2900 slave to my stack today and Fox ESS have updated everything again. Versions (which I am assured are the latest) are now :
H1-5.0-E-G2 - Master : 1.29 Slave : 1.02 Manager : 1.44
Batteries - ECS2900-2 - Master 2.000 Slaves 1.13
Datalogger - W4 - 4.13
If/when we get some sun again I'll be able to test whether the "if under mode scheduler battery Max SoC reaches 100% DURING a forced charge slot (it's fine if it's already at 100% SoC when a forced charge slot starts or if the "old" 2 forced charge slots are used regardless of SoC) then PV output is clipped to 0 instead of being used for house load then export" has been fixed.....
My system has was installed a little over a month ago. My Firmware was updated on Tuesday 19th Nov to the same at JimH's above. I have the same Inverter but a different battery model and datalogger FW version.
Batteries - EP5 - BMS : 1.003
I have had problems ever since the firmware update. Has anyone else has problems or similar problems to the below?
During the past 3 nights (the start time is not consistent) since the update the battery has started charging from the grid to 60% and stopping at 60% each night. During that time the power in the battery has not been used to supply my house, until up to 12 hours after the battery initially started charging from the grid. For example, on 19th Nov the battery started charging from the grid at 21:00 and it wasn't until 09:03 on 20th that power from the battery was powering my house again. During that time the battery level was maintained at 60% and the load was being supplied from the grid.
There are no force grid charging settings and no active mode scheduler operations set to account for this charging from the grid. To me it appears to be a problem with the firmware as it was not doing this when I was on inverter firmware Master : 1.18 Slave : 1.02 Manager : 1.28 prior to the 19th Nov.
Fox are investigating this currently but I was wondering if anyone had encountered this before and had any recommendations on what might be causing this, remedies?
Jordan
Jordan
I've found that a full system shutdown and restart (including batteries) can help/sometimes be necessary after a G2 inverter firmware update - have you tried that?Jordan wrote: ↑Fri Nov 22, 2024 11:06 am Hi
Jordan
Jim
JimH wrote: ↑Fri Nov 22, 2024 11:24 amJordan wrote: ↑Fri Nov 22, 2024 11:06 am Hi
Jordan
Jim
Hi Jim
Thanks for the reply, I've not tried that, I'm fairly new owner of one of these systems. Is that just a simple... find the power isolator for the system and turn it to the off position and then back to the on position?
Jordan
[/quote]
Hi Jim
Jordan
[/quote]
Hi Jim
Jordan
[/quote]
Hi Jim
Jordan
[/quote]
[/quote]
Thanks Jim, I've followed that video and have shutdown and restarted my system. Hopefully my issue won't occur tonight. Jordan
A quick update on my issue...
The full system shutdown and restart resolved the grid charging to 60% issue.
The power in the battery not being used to supply my house part of the issue was due to a software problem with the battery. By the inverters being on the most up to date firmware and the batteries being on this incorrect firmware, it was causing the batteries to appear to be in an idle state and neither charging or discharging. Fox say the issue is now resolved.
Over the past 48 hours everything seems to be working normally.
Just the “PV input clipped to 0 when battery reaches 100% SoC during a mode scheduler force charge period” bug to be sorted then - still waiting for newer firmware for that……
Further inverter slave update today :
H1-5.0-E-G2 - Master : 1.29 Slave : 1.03 Manager : 1.33
If we ever get any sun I'll retest the "PV output clippsd if SoC reaches 100% DURING a forced charge period" bug....
More updates in the last few days :
H1-5.0-E-G2 - Master : 1.29 Slave : 1.03 Manager : 1.48
Batteries - ECS2900-2 - Master 2.002 Slaves 1.13
Update 1 - Apparently this isn't a bug!!!!
Issue raised with Fox ESS :
Using Mode Scheduler :
PV output is clipped to 0kWh only when battery SoC reaches 100% DURING a force charge period (daytime - when there is PV output of course!) Battery then remains held at 100% SoC (as it should) but house load is taken from the grid (until the mode changes away from Forced Charge again) and available excess PV output during the forced charge period isn’t used either for house load or export. If the battery is ALREADY at 100% SoC before a force charge period starts then PV output isn’t clipped to 0 and is used as it would be in self use mode during the (unneeded) forced charge period.
Using “legacy” force charge slots :
The issue does not manifest – if battery reaches 100% SoC during a “legacy method” force charge slot PV output is maintained and surplus energy is exported to the grid (expected behaviour).
Fox Response :
During any force charge period defined in mode scheduler the inverter reduces its line voltage to c.0.2 volts below the line voltage. As a result only grid energy will be used during any force charge period. This is normal - Victron and Solis do the same.
The legacy charge periods work a slightly different way from the mode scheduler.
Thanks and kind regards
Martin Rimmer
My Reply:
Hi Martin and thanks for the update – but that’s both disappointing and confusing.
Surely Fox ESS wouldn’t have deliberately designed the mode scheduler to work differently from legacy charge periods, even if this is how competitors work?
Many of us users in the UK (especially on Octopus Agile and similar smart tariffs) set an afternoon charge period as a “standby” for poor PV days before any premium period rates start..
However on good PV days if the battery is not already at 100% SoC when the mode scheduler force charge period starts any PV being produced – whether surplus if the battery is close to capacity and the charge rate is reduced, or everything once the battery reaches 100% SoC before the end of the forced charge period goes to waste. Worse still, house load is then taken from the grid until the end of the forced charge period!
Even if this is intended behaviour, I can’t see why it would be desired by anyone – especially as it ‘s different to the legacy method and there’s no proper user documentation anywhere.
I’m now going to look at using Home Assistant to automate my charges via ModBus but would still contend that a firmware change needs to be made to avoid all of that wasted surplus PV, especially in the summer…..
@will - Could you please raise at your next Fox ESS call? I can't believe this is how they've designed mode scheduler - unless I've missed a use case somewhere it makes no sense at all to me....
Update 2 - I can confirm that the grid meter compensation setting is now there in H1-53.0-E-G2 firmware 1.48 as detailed in Will's YouTube video here:
is available, but that there's no front panel setting for it - I had to raise a Fox ESS ticket to get it set as I only have an end user account for Fox Cloud but it is working now...
Fox Response :
Martin Rimmer
My Reply:
Just had my install done, firmware as follows:
- H1-5.0-E-G2 - Master : 1.27 Slave : 1.02 Manager : 1.44
Battery - EP11 - BMS: 1.005
Datalogger - WW (?) - 1.00
I have a H1-5.0-E-G2 and 5x ECS2900 V1 battery cubes.
It has happily been running reliably on the following versions for many months:
Manager : 1.44
Master : 1.27
Slave : 1.02
But I want to take advantage of the new meter compensation feature, so asked Fox support to upgrade the firmware. To their credit they did with 24 hours, and now I have:
Manager: 1.49
Master: 1.33
Slave: 1.02
In the same request I asked for the ECS V1 firmware versions to be upgraded, as they are not all the same, but this hasn't been done. So I my ECS V1 stack currently looks like:
Master: 1.017
4x ECS: 1.12
1x ECS: 1.09
This didn't cause any issues under the older firmware (1.44).
However I now have a problem: after a few hours, the inverter restarts itself, and then the display locks up - displaying the following message, and the front panel buttons are unresponsive.
I can find no reference to this error anywhere online.
However.. the inverter continues to operate, the battery works fine, Modbus works, and there are is no error states logged either in HA or in the cloud. If I hadn't looked at the inverter screen I'd not have known anything was wrong. A full shutdown/restart sequence gets the screen up and working again, but a few hours later I find the issue recurs.
I'm not sure whether the battery firmware inconsistency is now an issue, or some other incompatibility has arisen. I've emailed Fox support, but currently no response from them. So I'm posting this as a warning to anyone else considering an upgrade to Manager 1.49, and to see if there's any advice.
Manager : 1.44
Master : 1.27
Slave : 1.02
Manager: 1.49
Master: 1.33
Slave: 1.02
Master: 1.017
4x ECS: 1.12
1x ECS: 1.09
== BMS Slave ===
BMS Reset...However.. the inverter continues to operate, the battery works fine, Modbus works, and there are is no error states logged either in HA or in the cloud. If I hadn't looked at the inverter screen I'd not have known anything was wrong. A full shutdown/restart sequence gets the screen up and working again, but a few hours later I find the issue recurs.
FoxESS H1-5.0-E-G2 hybrid PV inverter
5xEC2900 Energy Cube
16x400w JA Solar panels
Whole house EPS + manual changeover
Wallbox Pulsar Plus 7kw EVCP
2020 Nissan Leaf e+ Tekna
Intelligent Octopus Go tariff
And a very small electricity bill!
The later versions of BMS / Slave firmware have made quite a few changes and it doesn’t surprise me that you are getting errors with inconsistent slave firmware - the battery firmware upgrade must have failed to push out to the final battery so whilst waiting for Fox to get back to you check that any rotary dip switches are set to the correct number of batteries i.e. it should be ‘4’ for 6 batts (=numbatts-2), if it is incorrect reset it and restart the battery (power off and power back on again). Once all batteries are updated by Fox the error should disappear.
Thanks Dave. DIP switch is correct for the stack (5 modules = 3). Fox responded to my further request to harmonise the battery firmwares with “This has to be updated from the site as the remote update is not going through”. So I’m not sure what to do now, other than try the installer who installed the extra slave (the one on 1.09) for me.
The good news is that after a further reboot and starting system in the correct order (inverter, then batteries) the error has not recurred for over 24 hours. Now, in the world of real-time control systems I know this counts for little but is better than before.
My firmware was updated today by Fox , so now showing :
Master 1.35
Slave 1.02
ARM 1.52
Strangely, my EP11 batteries are still showing 1.05 rather than 1.06
Master 1.35
Slave 1.02
ARM 1.52
I’m stuck at
min 99% battery reserve
Min Soc 99%
I’ve been manually setting these when I charge my EV (once a week)
I decided to try and set a schedule to do it
But at the same time I’d left them at 99%
Now I can’t disable mode scheduler (I’ve tried EVERYTHING)
Have raised a ticket with Fox
Until it’s fixed I essentially not using my batteries
I presume I’m on latest firmware
H1-5.0-E-G2-WL
Master
1.40
Slave
1.04
Manager
1.31
Arrrrrhhhhh
Min Soc 99%
H1-5.0-E-G2-WL
Master
1.40
Slave
1.04
Manager
1.31
Arrrrrhhhhh
I’ve commented on your other post, but essentially you have 2 options - it seems the app is not disabling the scheduler master switch once it has been set, BUT you can still set schedules.
The minSoC setting endures after a schedule ends, so if youhad set it at 99% for 2am to 5am, it would remain at that level for the rest of the day - and because the scheduler is enabled you will not be able to change it via the app ir the inverter panel.
The way to do it, is to add another schedule that follows the last schedule and sets a workmode of say Self Use and minSoC back to 10% - it should allow you to do that.
Alternatively, have a look at the Energy Stats app by Al Priest (on ios and Android), it is used by thousands of people whoi favour it’s simplicity over the Fox app - but this app does disable the scheduler master switch when you turn off the scheduler.
