Mobile app is not allowing me to login and is always showing login has expired. I have changed password and the I am able to check via desktop version.
I have exactly the same problem. Just started this morning. Bounces back to the login screen with a popup saying "Login has Expired". Website foxesscloud works fine and I can see my system/status through there. I'm glad I'm not the only one seeing this. Must be a server issue.
Same here, v1 app and website working fine.
Yes, I have this too in the v2.0 app. The original app still works.
Same, can't log in. Says log in expired. Tick terms and conditions and then just bounces back.
Had similar problem but after multiple tries it now works on my Iphone
My v2 is allowing access again.
The V2 app has been having problems on and off today - Fox appear to be working on the servers.
Having the same issue again today. Keeps bouncing back to log in.
Fox BMS v2
Fox ESS Hybrid Inverter 3.7
Mira HV25 x5
Trina solar panels x8
Ohme Pro EV charger
Skoda Enyaq
Mira HV25 x5
Ohme Pro EV charger
Skoda Enyaq
The app is now asking me to make a plant ??
I'm having the same problem today; web site works normally, as does old version of app, but new version of app either says I am off-line, or refuses to let me log in.
I have the same problem with FoxCloud2.0. Just started yesterday. Bounces back to the login screen with a popup saying "Login has Expired". Foxcloud app V1 works fine as does website foxesscloud and I can see my system/status through those two.
Had the same problem earlier (make plant). Left it alone for a while and it reset itself. Think they are messing around with the servers.
mobile app login has expired and time out please try again messages
no data available on fox 2 app
emailed as per contact us instructions - no reply...
cheers budDave Foster wrote: ↑Fri Aug 16, 2024 11:39 amKeep an eye on this page, it’ll be updated
https://monitor.foxesscommunity.com/sta ... qLgWwo4kbQ
still not fully functioning
This update just posted by Fox ESS on the V2 app
From other users I believe that Energy Stats is still working well
