Re: Force Charge/Discharge on AC1 / Intelligent Octopus Go integration
HSC85 wrote: ↑Sun Jun 23, 2024 10:31 pm Hi
Did you manage to resolve the first of your queries:
I can't take advantage of the additional charging schedule off peak charging times or free electricity times outside of the normal off-peak hours as the battery continues to discharge when I enter those periods rather than charging from the grid.
I am trying to take advantage of the additional charging off peak but I am also draining my battery.
Is there a way around this?
If you set a charge period in the app for the time you want, but leave the 'charge from grid' switch off the inverter will not use the batteries and uses the grid instead. If you want to charge your batteries during off-peak set the charge from grid switch on.
I created some code to control the inverter mode via the API from HA.
Worked fine for me, so I've written it up if it's any use: https://github.com/Robbie1977/foxESS_HA_set_mode
