Right now, I want to be able to start the day with a full battery charge, and gather some data before moving to Octopus Flux. This step will also help me to asses the battery size, and upgrade it if necessary.
I believe that at its most basic a charging from grid window can be set up via the control panel. I have the 'User Manual' for the inverter, which seems to show installation steps really clearly, but for Operations, merely gives a 'Function Tree' of the menus.
- Is there any documentation to identify what each of the menu options means?
- I have seen mention of web access to the inverter, How does one access this/is there any documentation?
- Can this be done from the Foxcloud app (I have WiFi access to the inverter)?
