I suspect our terminology for the 'smart' meter is different here in the UK - our 'smart meter' is the meter provided by the energy supplier to measure how much energy you use, whereas the RS485 meter I mention is indeed the Chint DDSU666.
The Chint meter has 2 installation options, either with or without CT clamps - but if you are installing the CT clamp version then the only advantage is the greater cable length between it and the inverter supplied CT clamp.
The KH inverter supports DRM which would let you restrict export based on tariff and you can set the export limit remotely which would also allow you to change the export based on tariff.
I'm not familiar with it myself but you can also link your inverter with Amber to manage your system
https://help.amber.com.au/hc/en-us/arti ... SmartShift
