I have had my PV + battery system (see signature) for about 18 months and want to upgrade/tweak the setup, but the installer I used has ceased trading. I want to add a bit more battery flexibility, and am looking for a fairly local company to supply/install an upgrade.
I am looking to add an additional 4 x HV2600 batteries (giving the max supported for a single-phase setup), and upgrade the system firmware to enable forced export to the grid.
I didn't have an EV when the setup was installed, but do now, and have found that the Zappi Eco+ mode to feed excess solar to the EV doesn't work, and the energy flow is displayed backwards (import is displayed on Zappi as an export) - from reading the forum I suspect this is just a back-to-front CT clamp, but would like the installer to look at the issues during the battery installation visit.
If anybody has good experience of a company (pref. within an hour of Swindon) I'd be grateful if they could leave me some details (website would be ideal!)
Thanks,
Tony
FoxESS H1-6.0 Hybrid Inverter
3 x HV2600 (7.8kWh)
16 x 450w PV Panels
Zappi
EV Household
Re: Seeking Installer near Swindon
Post by Will »
Hi Tony,
I'm Exeter based but Swindon isn't too far away. You'll find my contact details here https://ecclessolar.com/
Do you know if you have V1 or V2 batteries?
Where are the batteries located?
Thanks,
Will
2 x KH & 1 x H1
I’m getting net-eco to install my fox equipment. They are Chippenham based.
