App currently showing System Offline
Just wondering if there is any planned maintenace with the Fox servers?
My app is currently showing that my Inverter is offline. The inverter screen seems to be ok with Power 42w / SoC 19% / Normal / correct date and time.
The wifi dongle is slow flashing red.
I have noticed on this forum that this is sometimes caused if the Fox servers are down for maintenance - is anyone else experiencing problems?
Re: App currently showing System Offline
Have just talked to a friend and his system is showing offline as well so guessing an issue at Fox.
Yes i’m seeing the same - the Fox servers that handle data receipts must be being worked on.
Yes. I'm the same. It went to this status about 19:30 UK time.
The same has happened to me. Inverter and battery are fine but app is showing offline and all values in the app are zero.
Same here.
Fox are aware of the issue and working to resolve. https://monitor.foxesscommunity.com/
Was about to post but seems to be a not confined to myself.
Great community, but any chance we can get rid of all these awful adverts everywhere!! Makes things so much worse trying to navigate around all these unwanted ads!
Ditto, just found the forum and was going to post the same. Glad to see that it's not just us newbies!
Not the easiest app or sytem to navigate when you are a complete beginner with the whole solar/battery thing as a whole!
Hi all is anyone seeing anything in the app yet?
kho9316829 wrote: ↑Fri Feb 21, 2025 8:52 am Hi all is anyone seeing anything in the app yet?
Yes all working for me, the Fox servers appear to have come back on-line around 1.19am (GMT)
Dave Foster wrote: ↑Fri Feb 21, 2025 8:55 am
So not working over here . Anyone else having this problem
Currently all working for me now.
All working now thanks
This issue seems to be affecting users differently. Nice to see some reporting everything restored but others (me included) still with an issue but right now the cloud services monitor still reports a fault. So I can be patient :?
EDIT: No sooner had I declared my patience than it was rewarded :D
Re:system
Is the system back online yet, My installers are due to reconnect us on Wednesday.
Regards Dave
Re: Re:system
davec wrote: ↑Sun Feb 23, 2025 10:59 am Is the system back online yet, My installers are due to reconnect us on Wednesday.
Regards Dave
Yes it was only a temporary outage (~8 hours)
My app is showing as offline today, is there a known problem
Yes earlier today, all appears to be back and running now
I have been through all the steps listed below, checked my connection, performed an inverter reboot and the inverter is still stuck in off mode.
The dongle has connection, is flashing slowly red and th inverter is flashing the green light quickly…suggesting it’s trying to upload a cut….
It’s been like this for over a week, any help?
mcnei7227s wrote: ↑Thu Mar 05, 2026 10:01 pm performed an inverter reboot and the inverter is still stuck in off mode.
Battery too for good measure?
mcnei7227s wrote: ↑Thu Mar 05, 2026 10:01 pm The dongle has connection, is flashing slowly red and th inverter is flashing the green light quickly…suggesting it’s trying to upload a cut….
Does it show up in the client list of your router too?
Hi had a new install today, everything was working fine until my accessory had a firmware update and now the app says that everything is offline.
The inverter is working and so are the 2 batteries.
As it’s my first day I really wanted to set it to charge overnight at the cheap rate but the app will not let me do anything.
Please help.
Inverter: x1 Fox ESS AC1 G2. 5KW 1ph AC Coupled inverter.
Battery: 2x Fox ESS EP12 11.52KW with heating.
Solar: 12 x Trina PV panels
Inverter: Solis S6-GR1P 3.6k
Ev charger: Easee home 7kw
Antlen wrote: ↑Mon Mar 09, 2026 8:05 pm Hi had a new install today, everything was working fine until my accessory had a firmware update and now the app says that everything is offline.
Please help.
Oh no, not the best start.
5. Battery off
Wait for your Inverter screen to go blank.
Then I do all of that in reverse.
Hi ,
Thanks for the quick response
I did try that and the inverter started and the batteries are working fine
The app, however still isn’t seeing them.
Incidentally I do not have an external dongle but have a little antenna instead. When I try to join the wlan it accepts my WiFi password and then says it’s connected but does nothing.
This is what I constantly get
