Hallo,
wie kann ich meine Daten aus FoxESSCloud exportieren und in Excel darstellen, bei mir will das einfach nicht funktionieren.
Die Daten werden immer in einem Format erstellt das Excel nicht vernünftig darstellen kann.
Datenexport
In the app you can normally export all your data as a report by going to Services at the bottom of the Fox 2 app, click on Data and then submit a data report.
If you're doing that, what isn't working or doesn't make sense to you?
2 x KH Series Inverters
Please be kind enough to post a screenshot of the app and highlight the button at the bottom of the Fox2.app that will take me to the 'Create Report' option.
At the bottom of the FOX2.app I only see three icons: 'Home', 'Device' and 'Me'.
What settings do I need to change to see this function?
Thank you very much!
In the V2 app, click on 'Me' at the bottom, then choose 'Data', you have to manually enter your inverter serial number (which you can copy from the Device/Inverter page) - then select the range of data you want Day, Week, Month (or custom) and choose the format (start with Standard) - it will then download the data report to your device where you can view or download it to a file.JKW wrote: Thu Jan 30, 2025 6:04 pm Please be kind enough to post a screenshot of the app and highlight the button at the bottom of the Fox2.app that will take me to the 'Create Report' option.
