over the last few nights at midnight the mode scheduler automatically re enables itself, and wipes out Grid charge settings.
The work mode resets itself to invalid (see picture)
I reset this to Self-Use and get the error below and have to turn off Enable scheduler in Energy Stats
The following day the mode scheduler re-enables itself at midnight.
Anyone know what i am doing wrong.
App version is 2.1.2
Manager version 1.70
Slave 1.02
Master 1.63
Darren
Mode Scheduler help
I think i have figured it out.
I think because I had set my Agile API and had the buy in price set as zero on the agile page on the web, the mode scheduler was seeing this and thinking it was set.
I have deleted the Octopus Agile API and will see tonight if my charge schedule is deleted at midnight.
I had the same, gave up and switched to mode scheduler instead. I do find that control of this in the Energy Stats app is much more intuitive than either of the Fox ESS V1 or V2 apps though....
Fox ESS H1-5.0-E-G2 Firmware - Master: 1.29 Slave: 1.02 Manager: 1.44
Fox ESS ESC 2900-H4 Cube Battery - Master plus 3 Slaves - All V2 - 11.52kWh Firmware - Master: 2.000 All Slaves : 1.13
If it is greyed out, it means your firmware does not support it.
Contact your installer or local Fox service with your inverter serial number and ask them to upgrade to the latest inverter firmware.
