over the last few nights at midnight the mode scheduler automatically re enables itself, and wipes out Grid charge settings.
The work mode resets itself to invalid (see picture)
I reset this to Self-Use and get the error below and have to turn off Enable scheduler in Energy Stats
The following day the mode scheduler re-enables itself at midnight.
Anyone know what i am doing wrong.
App version is 2.1.2
Manager version 1.70
Slave 1.02
Master 1.63
Darren
Does it stick if you set it on the website?
In the past there were sometimes issues when you set charge times / schedules via app rather than on the cloud. Might be worth a try.
I think i have figured it out.
I think because I had set my Agile API and had the buy in price set as zero on the agile page on the web, the mode scheduler was seeing this and thinking it was set.
I have deleted the Octopus Agile API and will see tonight if my charge schedule is deleted at midnight.
I had the same, gave up and switched to mode scheduler instead. I do find that control of this in the Energy Stats app is much more intuitive than either of the Fox ESS V1 or V2 apps though....
Fox ESS H1-6.0-E-G2-WL Firmware - Master: 1.57 Slave: 1.04 Manager: 1.43 Datalogger (internal wifi) : 2.09
Fox ESS ESC 2900-H4 Cube Battery - Master plus 3 Slaves - All V2 - 11.52kWh Firmware - Master: 2.019 All Slaves : 1.150
Fox ESS Firmware updates applied July 2026
Octopus Intelligent Go tariff
Did you have any luck turning off the scheduler? I’m having the same issue and hoping someone has managed to resolve it now.
I have recently installed FOX Ess H3. My App showing Mode Schedular but it is diabled. pls guide how to get this enabled for me?
If it is greyed out, it means your firmware does not support it.
Contact your installer or local Fox service with your inverter serial number and ask them to upgrade to the latest inverter firmware.
