Help with connecting Inverter to Home network.
matt24
Hello I have a H1-6.0-E Inverter and cannot see how I get it connected to my home network. Looking online it looks like I should be able to plug it in with an ethernet cable, the only port I can see to plug into is the COM port? is this correct?
I've attached an image of the bottom of my Inverter. Any help would be much appreciated!
ImAFK
I believe some models do not have the ethernet port and you have to use the modbus to gain access sadly. I had an inverter installed that looked similar but ended up getting it replaced
14 x 420w panels
FoxESS H1-3.7-E Inverter
4 x 2.5kwh batteries
canton7
Yep I have the same inverter. There's no ethernet port, you'll need to use a RS485 adapter
matt24
Hello thanks for the information, thats annoying! Where does the RS485 adapter plug into to? I don't seem to be able to find any good guides.
calum
FoxESS Modbus HA Integration
Contact Fox here
matt24
Hello thank you that makes it much clearer.
Good guide!
Mini project for the weekend, thanks :)
