Fox ESS server down. Any clue as to when it will be back
Server has been only partially working all day. I can't set the force charge or min SOC just get "timeout" or similar. Any idea when it will be working?
Re: Fox ESS server down. Any clue as to when it will be back
Hi I am having the same issue on the app and foxesscloud.com.
Luckily I have quite easy access to the inverter and can set my charge from grid times and SOC on there.
I have same problem.
My inverter (AC1 5.0) is up in the loft and very difficult to get at thanks due to the installer. I cannot find any way to set the force charge or min SOC on grid from the AC1 menu. Any help appreciated.
Thanks,
Martin
Sloanyd wrote: ↑Sun Nov 12, 2023 5:47 pm Hi I am having the same issue on the app and foxesscloud.com.
I have the same problem. How did you access the controls on the inverter?
From the display on the inverter.
Page 32 in the user guide contains the menu tree how to get to charge times and SOC settings.
I have the H1/AC1
Menu > settings > work mode > Charge time.
Menu > Settings > Battery > min SOC, Max SOC, ongrid Soc.
All working now
I'll leave this here just in case anyone needs it again - into Settings, Work Mode, Charge Times to change times manually.
