Inverter Showing Offline / Wifi Dongle Setup Process
The easiest thing to do is to change the SSID and password of the new router to be the same as the old one, then it will just connect automatically.
If you have to change the wifi dongle to match the new router - the default password is mtmt2020 (all lower case), the connection guide is attached.
2 x KH Series Inverters
New updated video showing how to connect your fox system to your wifi network using the fox app
