Fox KH9 not showing correct PV current
I have just installed a Fox KH9 (DIY install).
The problem I'm seeing is that the current shown on the unit does not match what is actually being sent.
It is consistently 1-2a less than what is measured. I've tried multiple meters.
What this means is that on a cloud day my unit is showing 0w of generation instead of 200-300w.
See attached photo. 1.2a measured vs 0.2a on Fox.
Anybody seen this before? I've tried resetting everything, factory reset and making sure firmware is latest - Master 1.64, Slave 1.02, Manager 1.60
Re: Fox KH9 not showing correct PV current
The firmware versions are not the latest, but that won't be the issue.
Anyhow, my own thought is that Fox 'use' some of the current to run the inverter, and therefore take this away. I could be totally wrong, but that seems to be what I think they are doing.
Apologies, I thought I was on the latest firmware as I was looking at the release notes page:
I've just found the Google sheets page with newer versions. I will ask Fox to update my firmware. Thanks for letting me know.
The problem for me is when it is cloudy I am seeing 0w generation at midday ( I have 8 x 480w Aiko panels connected in a single string ). My total solar generation for Monday was 0.5Kwh. When it is sunny it jumps up to over 3Kw but there is clearly something wrong. I haven't taken a clamp meter reading in the full sun yet, it is forecast sun today so hopefully will get that to see how much a difference there is in that scenario.
I did see about 500W in the mist/fog a few days back, did surprise me.
Well hopefully today is sunny so you can look and see, best of luck with your install.
Thanks very much.
Fox kindly updated the firmware but it has made no difference. I've now added a second string of 7 panels to PV2.
This means I now have 15 x 480w panels.
It was sunny on Wednesday and I took some more readings, in full sun it was showing a difference of approx 1.5A - about 340W per string, photo attached.
It is now 11.18am and light cloud and it shows 0W generation. I took clamp readings from both strings and it should be 200W.
please dont take this the wrong way as I dont know your competence level.....but you ARE zeroing the clamp meter by holding the closed jaw tips against the cable with the jaws closed first, yes?
I am an electronics hobbyist and have several DC clamp meters and the readings can vary considerably depending on where you zero it....apparently they pick up variances in the earths magnetic field and stray magnetic fields from any nearby cables so need to be zeroed as described immediately before every reading
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
Hi - thanks for the reply. I have 2 different clamp meters and both were zeroed in accordance with the guidance in their user manuals. I also asked a qualified electrician to check with his meter last week while they were installing a new consumer unit. Again this showed the same discrepancies between reading and screen.
I opened a support ticket with Fox but all they could say was that the differences were within acceptable tolerances.
ah yes, their standard get out clause :D
