Cables
The Cable that came with Fox ESS battery to meet Inverter is 3 meters long and with nowhere to go. Installers stuffed it down the back of the Battery!..If the lead is shortened will that negate the warranty as was suggested.
Re: Cables
Yes the lead can be shortened but you must use the connectors that are provided with the inverter for this purpose - they should have been left with the various bag of bits.
The battery lead won't cause any problems with it being 3 metres long as it is rated at maximum power for this distance, perhaps just a bit unsightly is all.
Re: Cables
What I did not like was being informed that shortening the cables would negate the warranty and it was acceptable to coil up the 3 meters and stuff it down the back of the Fox ESS battery against the outside wall! :o
Re: Cables
my installer did that as well.....you'd have thought they would have nicked 3m of heavy duty cable..... :D
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
