The Cable that came with Fox ESS battery to meet Inverter is 3 meters long and with nowhere to go. Installers stuffed it down the back of the Battery!..If the lead is shortened will that negate the warranty as was suggested.
Yes the lead can be shortened but you must use the connectors that are provided with the inverter for this purpose - they should have been left with the various bag of bits.
The battery lead won't cause any problems with it being 3 metres long as it is rated at maximum power for this distance, perhaps just a bit unsightly is all.
What I did not like was being informed that shortening the cables would negate the warranty and it was acceptable to coil up the 3 meters and stuff it down the back of the Fox ESS battery against the outside wall!
