App Mode Schedule | Force Discharge
Hello all
Should this setting work such that the battery both discharges to the grid and carries on supplying the house (assuming house load + discharge load < inverter limit) ?
I ask, because I'm sure that when I decided to discharge yesterday as a test (nominal 200W), my house load (500W) was then supplied by the grid.
Is my assumption wrong?
Rog
Re: App Mode Schedule | Force Discharge
If you instructed your inverter to discharge at 200W, then it's very literal. So your inverter created (supplied) 200W only, so the grid needed 300W to support your 500W load if those are your numbers.
I'm not sure if I expressed my question well enough @MaterialBarracuda48.
I was wondering, shouldn't the battery have supplied all the 700W, exporting 200 and supplying the house its 500?
What seemed to happen was that the battery exported 200W, but then the grid supplied the house 500.
Hi Rog, you cannot export and import at the same time, that's impossible on single phase. From your last post, it seems the load was 700W, 200W from Inverter (battery) and 500W came from the grid?
You need to think of the value you input of 200W as a HARD limit, that is all it will make, no more, no less.
So you instructed the Inverter to create just 200W, so when your load exceeded this amount then it had to get energy from the grid. Also remember the Inverter controls the energy that is released from the battery, hence you needed to import from the grid now. So that is why the battery was not able to supply the load, the Inverter was instructed to not allow more than the 200W.
An example, say you set Inverter to discharge 500W, it doesn't export 500W to the grid, this is how much it actually creates from the battery. Now if your house load is 200W, then the remaining 300W can and will flow out to the grid. If your load exceeds the 500W you set, now energy has to flow back from the grid to cover the load as it exceeds the value you programmed to discharge (create.)
understood, that makes sense. Thank you again @barracuda
