App Mode Schedule | Force Discharge
Hello all
Should this setting work such that the battery both discharges to the grid and carries on supplying the house (assuming house load + discharge load < inverter limit) ?
I ask, because I'm sure that when I decided to discharge yesterday as a test (nominal 200W), my house load (500W) was then supplied by the grid.
Is my assumption wrong?
Rog
Re: App Mode Schedule | Force Discharge
If you instructed your inverter to discharge at 200W, then it's very literal. So your inverter created (supplied) 200W only, so the grid needed 300W to support your 500W load if those are your numbers.
