Solar getting capped recently
Hello community,
I have a 13kw solar with 10kw H3.Smart inverter and battery installed almost a year back. The system was working very well so far. Earlier, the solar used to generate the maximum output (>10kw), as long as it can charge the battery and sell the excess to the grid. Recently i moved to a VPP provider. Not sure if its a coincident, but for the last 1 month, the maximum output for my solar is getting capped at 10kw, even though the battery has plenty of room to charge and i haven't set any grid export controls. Please see both screenshots, the one Feb'27 showing the solar producing >10kw as long as the battery has room to charge, then getting capped at 10kw once the battery is fully charged. In the latest screenshot, the solar is always capped to 10kw irrespective of the battery SOC. Does anyone faced anything similar recently? or any guidance if there is any settings that I can change to get the solar produce its maximum output?
Thank you for your help in advance!
Jerry
Fox ESS Inverter Installation
H3-10.0 Smart 10kW - 3 Phase
9 x EQ4800 (41.94kWh)
26 x 510w across 2 arrays (13.2 kW)
Re: Solar getting capped recently
Are you in Australia by chance?
Seems some VPP providers there will cap your power like this (as seen in previous posts on this forum)
MaterialBarracuda48 wrote: ↑Sun Nov 15, 2026 12:04 pm Are you in Australia by chance?
Yes, I am in Australia and with Amber. Is there anyway we could override this?
I did have a search in the forum for you, but do recall seeing it sometime in the past in regards to the hard cap. Since I think Amber takes over with VPP (Virtual Power Plant) controls, I think you are stuffed. It might be part of their tariff terms and conditions/rules that you can only import 10kW?
If you don't get any answers from your fellow Australian members, there is a dedicated section that might bear fruit if you reposted there viewforum.php?f=49 (wait a few more days to see if they reply here first) it might be also an idea to search for 'Amber' and see what posts exist here also.
I wish you the best of luck.
EDIT: I can see you have made a post to ask a member about the same issue.
MaterialBarracuda48 wrote: ↑Mon Nov 16, 2026 9:29 am I did have a search in the forum for you, but do recall seeing it sometime in the past in regards to the hard cap. Since I think Amber takes over with VPP (Virtual Power Plant) controls, I think you are stuffed. It might be part of their tariff terms and conditions/rules that you can only import 10kW?
Thank you for your kind response! appreciate it. Yes, found a thread when i searched up based on your suggestion. Will try my luck here and the other forums. Its hard to get a decent support from Amber as their automated agents pointed it as a hardware/firmware issue. Tried my installer as well, they are hard to get hold of as well once installation is complete. Pretty much we are left our own.
Yeah difficult with installers, as most just know how to fit the kit, but not much in depth details beyond that... and of course being ghosted for support.
