Solar getting capped recently
Hello community,
I have a 13kw solar with 10kw H3.Smart inverter and battery installed almost a year back. The system was working very well so far. Earlier, the solar used to generate the maximum output (>10kw), as long as it can charge the battery and sell the excess to the grid. Recently i moved to a VPP provider. Not sure if its a coincident, but for the last 1 month, the maximum output for my solar is getting capped at 10kw, even though the battery has plenty of room to charge and i haven't set any grid export controls. Please see both screenshots, the one Feb'27 showing the solar producing >10kw as long as the battery has room to charge, then getting capped at 10kw once the battery is fully charged. In the latest screenshot, the solar is always capped to 10kw irrespective of the battery SOC. Does anyone faced anything similar recently? or any guidance if there is any settings that I can change to get the solar produce its maximum output?
Thank you for your help in advance!
Jerry
Fox ESS Inverter Installation
H3-10.0 Smart 10kW - 3 Phase
9 x EQ4800 (41.94kWh)
26 x 510w across 2 arrays (13.2 kW)
Re: Solar getting capped recently
Are you in Australia by chance?
Seems some VPP providers there will cap your power like this (as seen in previous posts on this forum)
