self use or standby ?
I have set forced charge and discharge schedules......
There is an option under "After Discharging cut-off" for
Self-Use.........Feed-in.........Priority.........Back Up.........Standby
whats the difference between self use and standby
thanks
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
Re: self use or standby ?
This being Fox we have to work this out for ourselves, sadly i've got a gen 1 inverter and don't get any of these options - but from what I have been able to work out from others Standby holds all battery activity so it will not charge or discharge, whereas Backup will hold discharge activity but will allow charge from solar.
Self Use will operate as normal, charging from solar if available, powering the house if not (and battery above minsoc)
Pretty much what I thought
Thank you
