Re: Force discharge not working correctly
andrewv wrote: Tue Mar 17, 2026 11:12 am I can understand how some people will want something to work one way and some another.
But I'd say that forcibly changing the way something works, without warning, is an absolute no-no. If they want to introduce extra functionality, then they shouldn't do it at the expense of existing functionality. And let's face it, they're not deliberately introducing extra functionality here, they've done this by accident.
It has not made for the best customer experience, it works one day, then behavior changes overnight.
It was not an accident though, they made deliberate operating changes to what they believed their customers wanted :shock:
I still don't understand why someone would want a time period where they force discharge (presumably because they are selling), then when it reaches a certain SOC to then immediately run from the grid for the rest of that time period (which will presumably be at an expensive rate as this is a time period when it's profitable to sell, not buy)...
Given that this happened at the same time as two bugs (disabling my forced charging and limiting my import power rate), I'm not convinced anyone at Fox knows what they're doing.
And yes, all of the above about not springing surprise changes in functionality on people, intended or not. This is not currently the system I carefully researched and bought. And we're here discussing this as we monitor things closely - there are going to be people whose first realisation that their systems are no longer working as they believed them to be is when the bills come in...
There is a previous post from a few months back where someone had the opposite problem with charging.
viewtopic.php?p=12379#p12379
So FcSoC % and FdSoC % just acts now as an instruction for the battery to Charge/Discharge to xx%
Then it rides out the time period.
I agree it would be nice if they can adjust this behavior somehow to change behavior once it reaches this value, could be a future firmware change or some toggle that can be adjusted.
We did have a Dutch member IIRC post not too long ago about AI Mode being present in the FoxCloud2.0 App in their region, maybe that could solve it. "Discharge battery down to xx% between xx:xx and yy:yy time" and it then swaps work mode. Sadly not sure if this has taken off, and how it works as I don't think they posted details on this.
ETA: Ah, here it is, have a read... I am not sure if it is mature and how people are finding it IRL
https://fox-ess.uk/capture-ai/
If your force discharge schedule has reached it's cutoff soc it will stop discharging full stop until the end of the schedule. If you don't want to draw from the grid from the time it reaches the cutoff soc and the end of the schedule, you only have two choices. Change the discharge schedule to a shorter period, or limit the discharge power. You should decide which is worse, not discharging to the grid as much as you want, or buying from the grid. For my situation I have stopped forced discharging all together as we get very little from it anyway.
Thanks for the reply. Yes, I could do that, but I don't want to do either of those things as I don't know what the SOC will be at 8pm when I start discharging. It will vary according to the season and how much it's been used during the day. I have three forced discharge periods set up - 8-10pm to 48%, 10-11pm to 24% and 11-11:30pm to 12%. Then whatever the SOC is at 8pm and however much it's being used, it gets down to 11% at 11:30pm and it's time to charge it again at the cheap rate. And no importing from the grid at the expensive rate during the evening. To recreate this now I'll have to keep changing the rate or time depending on the season, how much I've used it each day etc.
I just want it to work how it did from when I bought it until three weeks ago, and I think it's quite reasonable to expect that.
Hi All, the last post I have seen on this problem was back in March and we are now coming up a month later on and yet I think the SW/FW has not been updated by FoxESS to address this issue. I would appreciate any feedback on whether Fox are actually going to revert controls back to the old system such that we can continue to use FD without incurring grid imports at peak rates or whether the only option is go down the Home Assistant route (which i think is beyond my skillset...)?
I have been chasing my installer - the last I heard was on 26th March when they said, "Sent your further feedback to them [Fox]. I'll update you on their response". So I guess I'll just keep chasing them. I'll post any further updates here.
The last word was "April" so you may have to wait a bit more before they release something. The latest FW release for the KH series was pulled, so I would rather wait a few weeks and get a stable release.
I hope it's OK to bring this up within this thread but it does relate directly to the words of the subject line:
I experimented with setting a Forced Discharge whilst the sun was still shining (so there was PV output) and was surprised to see that when I set FD to 6kW the actual battery discharge level was considerably less than the 6kW requested - in fact exactly the PV amount less (in this case PV was running at 4-5kW so only 1-2kW was being actually discharged from the battery). So this means that the actual battery discharge power is the set FD power less the PV power at the time..... I cannot follow why this should be the case, if I demand discharge then surely that's the rate that the battery should be discharged by? (Note at these levels I was well below the inverter power limit so that shouldn't have impacted the discharge power)
DustyDT wrote: Fri Apr 17, 2026 2:26 pm I hope it's OK to bring this up within this thread but it does relate directly to the words of the subject line:
That's the thing FD whilst implying force discharge power rate is not related to battery discharge, it is actually setting the inverters active power register to 6kW and so the inverter will fix it's AC output at 6000 watts. Assuming it is capable of achieving that it will fulfill it firstly through PV and use battery to fill in the rest (plus losses), so you'd expect to see a few hundred watts more going in than coming out.
Well, I've finally got this working correctly, though it's not an entirely satisfactory solution.
Even after two firmware updates it didn't work, so I ended up complaining straight to Fox who have now "enabled an extended parameter" for me. So now at least during a force discharge when it reaches the desired SOC it is back to running the house from the battery again rather than importing expensively from the grid.
But "this operation permission is not available to users", so if I ever want to modify my mode scheduler settings (I sometimes do another force discharge/charge cycle when Octopus have special free electricity promotions during the day) I will have to get them to do it again for me each time, which isn't very convenient.
No explanation as to why they changed the default functionality in the first place, or took so long to offer a solution.
Still can't believe this hasn't been fixed or allowed to be an option again in the app.
I posted months ago about the change and how it affected my schedules and since then I've had to actively monitor each day what my remaining battery level is so that I know if to force discharge or not.
  • Force discharge until specific time then switch to Self-Use
  • Force discharge until 15% SoC then switch to Self-Use
Simple options that can be added to our Scheduler mode relatively *easily.
* I work in the video game industry and mentioned this to our programmers after I complained about it during a break in a meeting and they said that it's quite easy to do - but I can neither confirm or deny this as I'm not a proggy. :mrgreen:
I'd recommend getting in touch with Fox direct as it seems that they can remotely set the required parameter.
service.uk@fox-ess.com - they will need to know your inverter serial number (which you can find via the app).
Like I said, it's not a perfect solution, but at least you'll be back to where you were.
Dependant on your hardware/firmware versions this has been fixed with he latest version (2.2.18) of the app.
Manager(ARM):1.76
Master:1.57
BMS:1.012
nrb501 wrote: Fri Jul 17, 2026 6:01 pm Dependant on your hardware/firmware versions this has been fixed with he latest version (2.2.18) of the app.
Perfect. I'll have to check for the update.
Edit: Just looked and in the app I'm missing the "After discharging cut-off" option.
Although at the bottom of a Schedule it states the following:
How the device works?
During 23:30 - 23:59, the battery discharges to your home and grid until it reaches 15% SOC, then switches to Self-use.
Both solar and battery discharge together.
Grid import and export are subject to the Import/Export Limit.
iOS app: v2.2.18
Inverter:
Master - 1.60
Slave - 1.02
Manager - 1.58
Battery:
Version_BMS - 1.012
Edit 2: Just doing an Export test to see if it cuts off at the correct SOC and reverts to Self-use.
Edit 3: Seems to have worked. Exported until hit set SOC and then reverted to Self-use. Just strange to have the missing option, but happy it works again.
I'm a newbie here and yesterday did my first "trial" export. I was coming on to post this exact problem i.e. after the forced discharge, power was drawing from grid so I switched the schedule off at that point.
Like @geekbyte, I too am missing the "After discharging cut-off" option and I too have the aforementioned version of the app on android. My difference is in where there screen says "During 23:30 - 23:59, the battery discharges to your home and grid until it reaches 15% SOC, then switches to Self-use." mine ends says "............then switches to ." so I am missing the words "self use". In fact its missing any words.
@spiral: What inverter model and what inverter firmware (master/manager) versions do you have? Its possible your inverter firmwares may need updating for these options to be functional.
Manager(ARM):1.76
Master:1.57
BMS:1.012
nrb501 wrote: Sat Jul 18, 2026 8:53 am @spiral: What inverter model and what inverter firmware (master/manager) versions do you have? Its possible your inverter firmwares may need updating for these options to be functional.
Cannot find anything in app that tells me either of this information. Could you please point me to where I'd see it.
Edit: Just found it on website, not sure why its not visible in app anyway its a KH7 with master version 1.60 slave version 1.02 arm version 1.58
To find the information in the app you need to go to the following;
Devices > Inverter > Click on the serial code of the Inverter > should show your details in there.
Same process for the battery and WiFi dongle.
spiral wrote: Sat Jul 18, 2026 9:20 am Edit: Just found it on website, not sure why its not visible in app anyway its a KH7 with master version 1.60 slave version 1.02 arm version 1.58
I am running
Master 1.69
Slave 1.03
Manager (ARM) 1.64
I am not sure if you can upgrade to these versions as they got pulled, although working fine for me.
I see Geekbyte has posted how to find version information, you can also just click on the home screen graphic on battery or inverter for 2nd way.
MaterialBarracuda48 wrote: Sat Jul 18, 2026 9:45 am
I am running
Master 1.69
Slave 1.03
Manager (ARM) 1.64
If I'm only running 1.60 of the master and you're running 1.69, there must've been 9 updates since my last one and I can't see any available. Where should you see them because even if 1.69 was pulled, presumably I should have 1.68 available.
spiral wrote: Sat Jul 18, 2026 9:50 am If I'm only running 1.60 of the master and you're running 1.69, there must've been 9 updates since my last one and I can't see any available. Where should you see them because even if 1.69 was pulled, presumably I should have 1.68 available.
Fox are a little bit like, "one, two miss a few" so FW versions do tend to jump. They might test/add features in between, and also can "upgrade" your FW during issues to 0.xy versions. Usually baked quickly to fix some error they have introduced.
If you follow Geekbytes directions, there is where you can find if you are running the latest, or if they have removed the upgrade possibility.
Click on your Inverter in the FoxCloud2.0 App and get up version information, and post screenshot here if you can please.
Cannot seem to attach picture without text.
Screenshot
Screenshot
It looks like they have turned off FW upgrades for a bit.
When working properly, you should see (Latest) or a (1.70) next to it.
In the forum, we have seen these versions posted.
Master 1.64, and latest is 1.70
Check once a week in the App for upgrades, or email service.uk@fox-ess.com with your Inverter serial number and tell them you are missing the feature to revert work modes once the desired SoC has been reached.
For the KH series, the latest versions available to agents/installers for download are:
Master - 1.70
Manager (ARM) - 1.66
Slave - 1.03
As suggested above, your best bet is to email FoxESS to get upgraded.
It does seem that the user's ability to perform inverter firmware upgrades has been pulled at the moment, datalogger updates still seem available.
Manager(ARM):1.76
Master:1.57
BMS:1.012
