Short(er) Version:
I'm convinced that this is a stupid question, but I have to ask it because I'm clearly missing something fundamental, despite me thinking I had a pretty good grasp on it all :/
Incidentally I've tried searching the community for related information, so I apologies if I've missed something.
I'm utterly confused by some of the data. When looking at the Energy Flow information (graphic) in the web interface, the flow direction (of the arrows in the animation) is TOWARDS the grid (as per screen grab below). Feed in Power shows a value (currently around 2 kw). I have no solar as yet and Work Mode is set to "Self Use".
Q: Why does it appear to be sending power to the grid or am I completely misunderstanding?
Many thanks for any help/advice.
Longer Version - in case more background is needed
Okay, so I've just had the Hybrid AIO installed with 4x HV2600 batteries.
No EPS installed or wanted.
CT clamp is on the live wire pointing in the direction of the Meter.
I have no Solar installed yet (coming at a future date when funds allow), so I'm simply looking to make use of battery storage until then.
Work mode is set to "Self Use".
I'm setup with both the web and app version of the Fox Cloud.
I'm with Octopus but I now need to find a suitable tariff (I'm on Tracker at the moment)- which I'll be looking at this week, to try and make use of Off Peak charging.
