HA integration to control mode scheduler without modbus
Hi all.
I've created a moderately simple HA integration https://github.com/nicois/foxess-contro ... /README.md intended to allow people without modbus to avoid the pain of relying on the mode scheduler provided by the mobile app.
I won't try to repeat what the README says in detail, just the key features:
- you can tell the inverter to charge your battery within a defined window, ensuring you reach your target SoC with a minimum of grid power (ie: where possible, waiting as long as possible to allow solar maximum opportunity to provide what you need). It will switch to self-use afterwards
- you can instruct the inverter to force-discharge during a window at a configured rate until a SoC is reached, at which point it switches to self-use. The FoxESS force-discharge threshold does not do this, instead pulling from the grid when you least want it.
You have finer-grained control too if you want it, but these two "smart" features are probably most of what people are looking for.
I only just created this, and there is a big HACS backlog to be natively listed, so unfortunately you'll need to follow the instructions to add a custom repository.
Don't hesitate to list any feature requests or bugs. This is only a couple of days old, so will still have a few rough edges.
Re: HA integration to control mode scheduler without modbus
This has been evolving pretty quickly, and I wanted to share just one of the recent additions:
If your energy provider pays higher feed-in rates at certain times of the day, smart discharge lets you control how much energy get pushed out, balancing your own consumption needs with the benefits of feeding energy into the grid.
In the above (contrived) example, there's a 55 minute feed-in period where the inverter will discharge at the maximum allowable rate - but it will stop after 1kWh has been fed in. This is useful when your retailer only pays good rates for the first X kWh per day.
You can also set the minimum SoC, which guarantees you will not run out of energy overnight. Whichever limit is reached first will cause your inverter to switch back to self-use mode.
You should attach your image, as it is blocked from viewing in some regions.
imgur doesn't work here ;)
I've added support for modbus as an option, so those users can also benefit from the more powerful automations offered by this integration. I don't yet have modbus working so I welcome feedback if there are any rough edges with this.
Another notable feature: when using "smart discharge", if it appears the minimum SoC will be reached before the period ends, the discharge rate will be reduced to avoid your hitting that SoC early.
There's also a custom dashboard card to let you see at a glance what's happening:
Looks nice - thanks for your efforts. It looks like it would be a nice easy way to send commands from HA.
I've got modbus working so will keep an eye open for anything
I was using the Nathan Marlor Energy Management Intergration, but that has stopped working following this last firmware update. I'll check yours out, as I just need a simple way to start and stop the force charging. Thanks!
Just came across this post, of this HA integration .... just wondered how people are getting on with it. I have Modbus integration, and reading through the GitHub .. there seems to be a lot of features in this
Turak64 wrote: Wed Apr 29, 2026 8:56 am I was using the Nathan Marlor Energy Management Intergration, but that has stopped working following this last firmware update. I'll check yours out, as I just need a simple way to start and stop the force charging. Thanks!
did you get this working? I've hit the same issue due to the new version :(
I came across this when researching what hardware I may have to buy and install to be able to control my FoxESS equipment via Home Assistant, as I was getting frustrated... I have Octopus Intelligent Go, and when it delivered cheap slots to charge the car, it just drained the battery - that meant I spent way too much time checking the dispatch slots, and then going into the FoxESS app and setting a forced charge to ensure the car charged from the grid (and filled the battery at the cheap rate).
I had the old 'view only' integration working OK, but struggled with not being able to control the inverter/battery, so this looked just the ticket - and no hardware to buy!
It is early days, but I now have a Home Assistant automation that sees the cheap dispatch slots, and automatically sets 'force charge' during those periods. It can be challenging to get dispatch slots outside of the 23:30-05:30 period, but the couple I have had looked to have worked OK.
I will update here when I get more data.
Great work Nicois, thanks.
Could someone please give a brief overview of how Home Assistant would work with Fox ESS KH10 inverter? I would like some way to schedule my charging/discharging of battery, so I don't have to check it all the time. I'm new to all this, and some questions I have are:
  • Do I need to install and have HA running on a computer or something 24/7? Can it go on Windows or needs it's own VM or what?
  • Does Modbus need some hardware connection to inverter?
  • If I use this integration instead, can it just access the inverter through the cloud API or something, and doesn't need any special hardware added to inverter (as long as inverter is connected to cloud)?
  • Will this use of HA allow scheduling for different days of week and times, or even special dates?
Thanks!
HI
I have to start by saying I'm by no means an expert on this or Home Assistant, and I also don't really know what a KH10 inverter is in comparison to my H1, but I'll have a stab at some answers anyway, and others can flesh things out and/or correct me.
Q - Do I need to install and have HA running on a computer or something 24/7? Can it go on Windows or needs it's own VM or what?
A - Yes, Home Assistant needs to be running all the time to offer any form of automation, be that lights, heating or managing your inverter. I happen to run mine on a Raspberry PI 4, but I believe it can run on a Windows VM (https://www.home-assistant.io/installation/windows/).
Q - Does Modbus need some hardware connection to inverter?
A - Until recently (as far as I am aware) you needed to add a bit of hardware (Modbus) to your inverter to allow control over modes and charging. I was never really up for adding hardware to my inverter, so I used the previous 'view only' Home Assistant integration for a while to see what was going on, then resorted to manually changing things in the app, which was painful! I found this integration the other day (it's fairly new), and this DOES allow control of my inverter without adding any hardware.
Q - If I use this integration instead, can it just access the inverter through the cloud API or something, and doesn't need any special hardware added to inverter (as long as inverter is connected to cloud)?
A - Exactly what this does, with this integration you get to see a huge amount of information using the cloud API (assuming your inverter is connected), but you ALSO get to control it.
Q - Will this use of HA allow scheduling for different days of week and times, or even special dates?
A - With Home Assistant the world is your oyster, you can make it do pretty much anything you want, pretty much whenever you want. I use Home Assistant to control all sorts of stuff in my house, but I now use it to discharge the battery overnight (paid export) and then charge it up again during the cheap electric window. I also have Octopus Intelligent, so when that delivers me cheap electric slots for the car during the day, Home Assistant now starts the battery charging at the same time without my intervention.
As I said in my other post, it is early days for me trialling this, but so far things have looked good.
I developed this integration against my KH10 so I can guarantee it works fine with it. If you have any problems or identify missing features, don't hesitate to tell me!
I've had a few people asking about whether there's a simpler way to use this, without needing to run HA. There are some online services with free tiers which apparently let you do some of what this integration allows, but Home Assistant provides a lot of control, at the price of needing to install it somewhere in your house, and learn how to configure it all.
I said I would update things...
This appears to be a brilliant integration - it has transformed my usage of the FoxESS system.
Before installing this I was nervous about plugging the car in (as it drained the battery) and had to spend my time watching the Octopus app and changing schedules on the FoxCloud app to cover things. Now I plug the car in and the integration handles everything.
Better yet, tonight there was an Octopus saving session, and Home Assistant auto joined me to the session when it was announced, and the integration ensured I was exporting power during the saving session period - again, no input from me (other than watching the magic happen in front of me!).
I'd just like to thank Nicois for the effort that has been put in. If there is any feedback or information you need, just shout...
Just an FYI/heads up, it doesn't seem possible to enable the Addon without providing API Key.
I was intending to use Modbus.
Is the API key still required? Is this a bug (feature) or oversight on install? i.e. could the user be provided a toggle to chose API/Modbus at time of install?
If you install the modbus extension too, you can still use it. It's referred to as entity mode in the readme.
I've already got the Modbus extension installed. But in order to add/enable "FoxESS Control", it first prompts for API information :(
It should be optional. If you provide it, it will be used as a fallback, but you should be able to configure the modbus entities without providing any keys.
nicois wrote: Tue Jun 02, 2026 12:44 pm It should be optional. If you provide it, it will be used as a fallback, but you should be able to configure the modbus entities without providing any keys.
Looks/sounds like a bug in the enabling of the addon workflow then. I’ll get some images.
I have an installer account so can’t get the API info from ‘user profile’. Nor do I want to expose my setup to the web.
I haven't seen bug reports from other modbus users. Have you installed the modbus extension in a nonstandard way which might be causing my extension to not think it's present, and so hiding the entity mode configuration workflow?
Tomorrow I'll push out a release which should help capture some more information when people make bug reports. This might show what's different about your setup.
nicois wrote: Tue Jun 02, 2026 12:59 pm I haven't seen bug reports from other modbus users. Have you installed the modbus extension in a nonstandard way which might be causing my extension to not think it's present, and so hiding the entity mode configuration workflow?
I have v1.13.6 of foxess_modbus installed via HACS. This was installed ~12 months ago.
I have just stumbled across your addon and installed it this morning, when trying to install the Addon via Integrations > Add Integration > FoxESS Control, the first thing I see is;
Which is prompting me for API Key and Serial number, both of which are required fields. So I am unable to proceed without populating the details. I'm assuming a connectivity check occurs when submitting, as entering dummy details does not work.
Unless I'm doing something wrong, having the ability to select "Modbus" at this point in time would be really beneficial, no?
Just to continue to feedback on this integration...
Things are still working pretty well, however something has caused an issue with the smart_charge (and possibly the smart_discharge). It looks like it is struggling to use the WebSocket correctly now, meaning the system is dropping back to the cloud API (which polls less often I believe).
I'm still not 100% sure what has caused things to change, as everything was working perfectly... However, an update to the integration and an update to my inverter firmware (Manager 1.76 and Master 1.57) occurred the same day, so it seems to be one of those that have caused this problem - my gut feeling is that is something FoxESS has changed.
I will continue to report back...
I’ve ended up getting Hermes Agent to drive Home Assistant now using its own self-aware AI controls, and as such doesn’t require a plugin, though it does utilise the Modbus plugin to drive the inverter etc
I’d still be keen to try this addon out however
