Force Discharge issue - reverting to grid not battery at end of schedule
I set a force discharge each evening, with FD cutoff at 15% so I have 5% left to use which sees me into the cheap rate window. However, instead of reverting to battery use at the end of this schedule, I am pulling from grid. This seemed to change when I was upgraded to 1.09 as it worked as intended previously. Having had a further upgrade today by my installer, the issue still persists.
I am in contact with Fox head office tech support, who are not aware of this problem, and tell me firmware logic hasn't changed.
If anyone experiencing the same could reply to this thread with your firmware versions, it may help them track down the problem.
Many thanks
Russell
H1-5.0-E-G2
EP11
Master 1.47
Slave 1.02
Manager 1.66
Battery 1.011
Re: Force Discharge issue - reverting to grid not battery at end of schedule
If at the end of your schedule, the battery is too cold, then it will pull from the grid to maintain a certain min temperature.
So make sure to read your battery temperature at this time to rule this out.
Yes noted, but I dont think this is the issue
RussJH wrote: ↑Mon Jan 05, 2026 4:39 pm Yes noted, but I dont think this is the issue
As long as you test this later, then as said it rules it out.
Just to clarify for myself and others.
It worked when it the BMS was below v1.009 (typo in above 1.09)
Stopped working correctly when upgraded to v1.009
And error remains on v1.011
It is an issue that has been extensively reported by users in
viewtopic.php?p=10811
viewtopic.php?t=2503
Should be pretty easy to fix:
If 'Force Discharge selected' AND time is between 'Start' and 'End' time AND "SOC>FDSOC", proceed to use 'Force Discharge', otherwise revert to 'Self Use' mode.
But for some reason Fox thinks it is "otherwise revert to import from grid".
It has been reported that mode scheduler is getting an upgrade in Jan/Feb this year so hopefully it will get fixed when this gets released. The issue is definitely holding back recommendations for the Fox Brand in Australia.
Confirming I am also having this issue. Feb 2026. FoxCloud 2.0 Android App.
I still have this issue with my kh10/ep11 setup.
As it's getting sunny now in the UK, this is a real problem as forced discharge can't be relied upon to return to self use when the FD soc is met.
Has anyone heard of a fix to this yet ? Other than to start using home assistant....
I logged a support ticket with FoxESS more than a week ago but not had a reply. Very poor support.
I have just discovered this issue also and have emailed UK support as their online support ticket errors at the captcha
Do they realise how massive a problem this is??!!? There is literally no point in having a peak time discharge schedule if it doesnt revert to self use when the SOC is reached. Because during this period any saving you are making is more than being cancelled out by the input grid premium tariff
They need to fix it urgently
I have disabled my force discharge schedule until they resolve it
Swift positive update from Fox UK support
"Dear Nicholas,
You are absolutely right. The recent update altered the discharge logic, and we have confirmed this with our R&D team.
They are currently fixing the software to restore the previous "Self-Use" behavior. A new version will be released very shortly to rectify this. Please keep an eye on your app for the upcoming update.
We apologize for the inconvenience and the issues you had with our online form.
Best regards,
Tristan"
I call this the 99% SoC bug
I use a schedule (in app or the energy stats app) to do a forced discharge and after it does not revert to self use or feed in priority
Starts pulling from the grid.
I check my settings in Quick settings and the min Soc is on 99%
ANOYING
Recently it won’t even do a forced discharge.
It’s like if a set a schedule to force discharge it does the opposite and starts charging my battery.
Very broken at the moment.
Raised this bug 2 weeks ago with fox and had no reply yet.
Just looked at data logger and it’s offered the upgrade to 2.09
Master 1.51
Slave 1.04
Manager 1.35
H1 5.0 E G2 WL
4xEP6
It’s 4th April 2026 btw
Why can I never see date people post. Am I being stupid. ANOYING
7.2kw PV
16 x 450w JA Solar All Black
12 x SE
4 x NW
Fox H1-5.0-E-G2-WL Inverter
Fox EP6 Batteries x 4 (23.04kwh)
Ohme Pod Car Charger
Not sure about your exact issue but the issue we are reporting is that after it hits the min soc for forced discharge it does not revert to self use and uses the grid. Fox are aware and working on a fix. I had a recent update to say they are testing the fix prior to release
Put simply
I have min Soc at 20%. I don’t change it
It jumps to 99% all on its own if I run a schedule
7.2kw PV
12 x SE
4 x NW
Yeah sounds like a different additional problem
System not reverting to self use mode after forced discharge mode limit reached (e.g. 50% SOC). This is a issue that should be fixed easily and quickly by Fox Ess
Yes but it hasn't to date. As I said they know about it and are deploying an app fix shortly. The fix is going through test at the moment according to Fox UK support
Update
They have upped my firmware today even though it was saying it’s on the latest.
I’m now on
Master 1.53
Slave 1.04
Manager 1.39
Data logger 2.09
It’s April 13th
Update April 14th
Ran a forced charge for 1.5hrs and then reverted to feed in and the min Soc has stayed at 20% not jumped to 99%
Energy Stats app no longer works though 🤪
But that’s fine for now.
7.2kw PV
12 x SE
4 x NW
I still had issues.!!
But now resolved (I hope)
I had a hidden to me time2 schedule with 99% min Soc
This could not been seen on Fox app Fox website or Energy stats app
Fox support were very helpful. Just took some time.
I hope energy it’s app will work again now because I could not do a force charge with it at all.
It was well broken.
I’m chilling for a few days to make sure it’s all stable till I try Energy stats again
7.2kw PV
12 x SE
4 x NW
Glad it's working for you but this post is about a different issue about the reverting to self use following hitting the min soc which is still awaiting a fix from Fox in the app
I just tested this with KH Version Master 1.67, Version Slave 1.02, Version ARM 1.58 and if force discharge ends before time window due to soc being reached it reverts to grid import instead of self use.
I am requesting the ARM be updated to Version_ARM: 1.61 to do a retest on that latest available firmware. Appears fox are testing my system know as the scheduling has been locked out for me....
Once the schedule conditions for ending are met it should revert back to what the user has selected for "Remaining Time Slots" or maybe even better suggestion is allow users to select during the specific window what to do with system during the rest of that schedule window ie "self use" ie prioritise solar & battery for home load or "backup" ie prioritize grid use, over battery use ,with solar first source of home usage.
There are separate cases depending on force discharge or force charge for different use cases:
1 - Force discharge of battery ->"Self Use" during remainder of schedule window- once force discharge complete you want to revert to self use as you want to use the battery or solar generation in the scheduled time window. ie in a peak time period and don't want to use grid and be charged. need to export during peak period to gain large feed in tarrif, but dont want to be then charged for using power when have available battery/solar.
2 - Force discharge of battery -> "Backup" work mode during remainder of schedule window - Battery discharged then want to be on grid power. User discharges battery to specific level to get feed in tariff and then wants to use electricity to provide? Not sure when this would be needed.
3 - Force charge of battery -> then "self use" during remainder of schedule window - charging up battery and want to go to self use after topping up battery and don't want to use grid power once battery charged up to soc level. Doing a battery top up as it is low but no free power during that time slot so then want to revert to self use.
4-Force charge of battery -> then "backup" work mode ie grid power during schedule window - charging up battery and want to stay on grid power during the window as it is an electricity plan with free electricity during that time period, so want to save battery.
Would be good to give users the choice in the "Work Mode & Mode Scheduler" when selecting manual scheduler in each schedule window option for "Remaining Time" - "Self Use" or "Backup", default it to what the user selected for "Remaining Time Slots" but have option to change it to either "backup" of "Self Use"
Tested with version KH master 1.67, Manager ARM 1.60, Slave 11.02
and same issue during schedule window soc reached on forced discharge and then reverts to grid use during the window.
Requesting Manager/ARM 1.61 firmware to test if it differs.
But each schedule window should have the option "Mode When Complete Before Window End" - "Self Use" or Backup" Would fix this for every fox ess user
Tested with ARM/Manager firmware 1.61, Master 1.67, Slave 1.02 and same result during window if soc reached while doing forced discharge the system goes to grid import for the house load not self use mode.
Fox please do the following add the option to scheduled times "Mode When Complete Before Window End" - "Self Use" or Backup" Would fix this for every fox ESS user.
Read previous posts. Fox are aware of the problem and are testing the fix currently
Since having this issue with grid import after a forced discharge period back in Jan/Feb time, seems my kh10 has stopped having this issue at some point in may 2026. I've noticed a few times over the last couple of weeks it hits the fdsoc % and whilst foxapp 2 still shows it's in force discharge mode, it starts to recharge the battery using solar just like it was in self use mode. Much as it always did last year before I updated the sw.
Has anyone else noticed this ?
I have a kh10 running master 1.60, slave 1.02 and manager 1.58.
I haven't updated it since Jan/Feb time but all of a sudden come may, it seems to be working again and no longer importing from grid once fdsoc % met.
Like some kind of bizarre magic ? Did anyone also experience this, and if so any idea what made it change ?
