I set a force discharge each evening, with FD cutoff at 15% so I have 5% left to use which sees me into the cheap rate window. However, instead of reverting to battery use at the end of this schedule, I am pulling from grid. This seemed to change when I was upgraded to 1.09 as it worked as intended previously. Having had a further upgrade today by my installer, the issue still persists.
I am in contact with Fox head office tech support, who are not aware of this problem, and tell me firmware logic hasn't changed.
If anyone experiencing the same could reply to this thread with your firmware versions, it may help them track down the problem.
Many thanks
Russell
H1-5.0-E-G2
EP11
Master 1.47
Slave 1.02
Manager 1.66
Battery 1.011
If at the end of your schedule, the battery is too cold, then it will pull from the grid to maintain a certain min temperature.
So make sure to read your battery temperature at this time to rule this out.
Yes noted, but I dont think this is the issue
As long as you test this later, then as said it rules it out.
Just to clarify for myself and others.
It worked when it the BMS was below v1.009 (typo in above 1.09)
Stopped working correctly when upgraded to v1.009
And error remains on v1.011
It is an issue that has been extensively reported by users in
viewtopic.php?p=10811
viewtopic.php?t=2503
Should be pretty easy to fix:
If 'Force Discharge selected' AND time is between 'Start' and 'End' time AND "SOC>FDSOC", proceed to use 'Force Discharge', otherwise revert to 'Self Use' mode.
But for some reason Fox thinks it is "otherwise revert to import from grid".
It has been reported that mode scheduler is getting an upgrade in Jan/Feb this year so hopefully it will get fixed when this gets released. The issue is definitely holding back recommendations for the Fox Brand in Australia.
