Hello, I just installed a Foxess H1-6.0-E hybrid without battery connect to it. I'm thinking of buying battery in the near future. My problem is I do not see a way to disable the battery check and the inverter is always giving a warning : "communication fault between battery and device" and a red light is blinking. Can anyone help with a way to tell the inverter that there is no battery to check and remove the error? Thanks.
Master version = 1.37
Slave version = 1.02
Manager version = 1.36
You'll want to be on the latest version of the firmware and follow these instructions. I've created a post on this subject here viewtopic.php?t=28
