Setting Meter Compensation
After watching Will's YouTube video on setting the meter compensation to a negative number and getting the inverter firmware updated to 1.37 I thought I would do this on my KH10. But for the life of me, I can't find the setting. The path I followed was:
Menu
Setting
Password 0,0,0,0
On-Grid
Then I went down the menu starting at Safety, Export Controletc but no Meter Compenstation.
can anyone tell me how to find it?
Thanks, Hugh
Zappi V2 charger and 2 EVs.
Re: Setting Meter Compensation
I’m sorry to say, it’s not available through the inverter menu’s, only an installer level account can access this remotely - Will has suggested getting your installer (or Fox) to start with a setting of -50 watts - I can’t offer any more help as my inverter doesn’t support this feature :(
Thanks for that. I will ask Fox to do it as my installer would come last in a three-legged tortoise race.
Here is what worked for me.
1) remove your battery from current account
2) create a installer level account (you'll need new username and another email address) using the app. You can just use "Username Pty Ltd" as company name if it asks
3) Add your battery into the installer level account
4) change meter compensation level
5) remove battery from installer level account
6) add battery back into original account
This was the exact process I followed and it worked.
hassangondal wrote: Thu Mar 05, 2026 3:33 am Here is what worked for me.
I just tried to do all that but the app just says unbindable when I delete the plant from the owner account because it's probably still linked to the installation company.
How much does a replacement datalogger cost?
evilbunny wrote: Thu Mar 05, 2026 9:54 am I just tried to do all that but the app just says unbindable when I delete the plant from the owner account because it's probably still linked to the installation company.
To answer my own question, I now don't need a new datalogger because the v1 web portal still allows battery systems to be bound to a different Agent/Installer account.
https://foxess.evilbunny.org/doku.php?i ... er_account
Hi there - any hints on setting an Agency ID in order to create an installer level account?
I too wish to set Meter Compensation.
Thanks!
Dan
Danto wrote: Sun Mar 29, 2026 5:29 pm Hi there - any hints on setting an Agency ID in order to create an installer level account?
You need to create an Agency account first, then generate an invite code, then create the installer account using the invite code.
Thank you.
I want to trial and error my Meter Compensation without the faff of emailing fox support every time.
How "safe" is it to create an installer account and use it? Will it void any warranty? Do Fox see that you're using an installer account?
