hi
ok so I currently have a Forced charge schedule set up for over night cheap rate between 01:00 - 05:25. Do I add another window and set that from 05:30 - say 21:00 ?
The app/website now seem to have a default mode for when no schedules are explicitly set, so you just need to add schedules when you want the battery to do something other then the default setting.rolotwix12 wrote: ↑Tue Mar 03, 2026 12:01 pm ok so I currently have a Forced charge schedule set up for over night cheap rate between 01:00 - 05:25. Do I add another window and set that from 05:30 - say 21:00 ?
If you only want them sometimes, just disable them and re-enable when you want to do it again, the site/API seems to have a 100 schedule limit, so add away to your hearts content.
Thanks.
Just wondering though in the schedule for Forced charge, I don't want the battery to charge from the Grid during the day when producing Solar energy, so how do I set the schedule up. I want the system to charge from Solar energy during the day upto 90%.
I have a schedule set as follows, this one I need to have batteries charge from Solar only upto 90%
Forced Charge 05:30 - 23:00
Charging Cut off - 90%
Charge power from Grid-0.00w
Charging from Grid - Disabled
Status -Disabled.
And another Schedule set as follows which makes sense to use cheap rate electric to charge batteries if required.
Forced Charge 01:00 - 05:25
Charging Cut off - 65%
Charge power from Grid-10500.00w
Status -Disabled.
Status -Disabled.
Status -Disabled.
