New WiFi provider
Jomaudeclark
I have switched WiFi provider so I’ve lost connection to my solar panels. How can I delete my FoxCloud account and re set it up with new WiFi. It keeps reconnecting to my existing account with the old WiFi. I know I’ve got to scan the QR code on the WiFi stick in the solar batteries in the attic at some stage. How do I get to that stage? 🤦🏼‍♀️
rmhumphries
There should be a wifi network showing with a name in the form `W-....` - for instance 'W-AAA1AAA'. Connect to that network (default password is 'mtmt2020'). You will get a warning saying the network has no internet - choose to connect anyway.
Once connect, go to 192.168.1.1 in your web browser. You can then change the WiFi details the datalogger will connect to on that page.
SolarEdge PV + FoxEss H1-AC1-5.0-E w/ 3x HV2600-2
Jomaudeclark
Do I just need to enter correct WiFi from drop down and password? The Mac details are different to the ones on the back of the router. It’s said it’s saved once but the app still says off line. Tried it again and now the blue circle is just going round and round in the screen...... 🤦🏼‍♀️
Jomaudeclark
OMG! It’s working!! Thank you SOOOOOO much.
rmhumphries
No problem - glad you got it sorted :)
PeteNZ
I have just had the same situation—switched to fibre finally with new router. Searched for a solution to re-establish wifi connection and nearly gave up as nothing seemed to work. Searched this site ,saw this post and solution—job done. So many thanks rmhumphries. PeteNZ
Ched
Alternatively change the new router networkname and password to the same as the old router. That way you don't need to change all your devices!
PaulL
Still having problems. I log into the datalogger but can only get to 192.168.1.1 by connecting to my Wifi instead.
Is the password asked for there the datalogger password mtmt2020 or the Wifi password ?
Doesn't seem to like either. :cry:
Update - had an IP engineer on the phone to set up phoneline. Apparently 192.168.1.1 needs the admin password not the WiFi one.
PaulL wrote: Tue Oct 17, 2023 4:45 pm Still having problems. I log into the datalogger but can only get to 192.168.1.1 by connecting to my Wifi instead.
As long as the screen looks like the below guide (from step3), it’s the datalogger password - but you have to connect to the dataloggers ssid itself first not via your wifi.
PaulL
Wow thanks - at first got " cannot connect " but then it did ! and it even looked like the picture
Now got one of the inverters showing one more to do. :D
7BW Solar
Excellent help rmhumphries, thank you. I had the same issue which thanks to you I have now solved. Quite proud of myself.
The only issue I had was that my iPad kept reconnecting to my home WiFi router which slowed things up a bit. If the ‘connecting’ message in the stripey bar persists, check that your device is still connected to the W…………… one.
dollarj
Hi I have recently got a new BT router. I have tried the above steps to reconnect my solar set however when I get to the box my new wifi isn't listed in the drop down. Lots of neighbours wifis are there and my new wifi appears on my phone and on my laptop. Any advice please of what I need to do?
I tried renaming back to old one however it didn't work and also when I tried connecting still didn't get the renamed old wifi ssid in the drop down.
Please help if you can
So a couple of things, firstly is the range of the new router as good as the old one - i've heard the BT routers range is lower than some, but I can't confirm that myself. If you stand next to the inverter with your phone is the signal strength still good ?.
Secondly most modern routers transmit on 2.4Ghz and 5Ghz - the datalogger on the inverter only works on 2.4Ghz, so you need to be sure that your router has the 2.5Ghz band enabled.
Just in way of an example for the way i've done this - I have a wifi extender (one of these https://www.amazon.co.uk/gp/product/B08V5KZCXV) - I have it plugged in approx half way between the main router and the inverters location and linked it to the main router. I've then given the extenders wifi name a unique name (like 'myinverter') and disabled the 5Ghz band. That means everything in the house will use the normal router, I then link the inverters datalogger to the 'myinverter' wifi name and as it is only 2.4Ghz there will never be a problem with it.
PMacSee
I've had the same issue after a IP change, but when I get to the details page all the fields are blank and there's no option for my house WiFi, it just says "nothing".
Can anyone help with how to populate the details?
That suggests that the new router might not have the range the previous one did.
You can try a reset on the datalogger to see if that improves things, it's fiddly to do it as you have to unscrew the collar at the top of the datalogger and then pull downwards, leave it 30 seconds and then plug it in and tighten the collar up. If you can't get access to collar the other way to do it is a full shutdown, restart of the inverter - there's a video guide here that explains that viewtopic.php?t=5
If that doesn't resolve it, you'll need to get a wifi range extender to increase your range, I use this one https://www.amazon.co.uk/gp/product/B08V5KZCXV which is very reliable, I disabled the 5 Ghz band, named it uniquely for my inverter and it's never let me down.
Will
Simple video guide here for setting up the wifi network.
2 x KH Series Inverters
rafal.baranowski5
I cannot change the wifi SSID, it shows nothing. I tried all above but the 192.168.1.1 page keep initializing data but with no success, no IP nor Mac shows up. How to reset the wifi dongle?
rafal.baranowski5 wrote: Thu Aug 29, 2024 3:54 pm I cannot change the wifi SSID, it shows nothing. I tried all above but the 192.168.1.1 page keep initializing data but with no success, no IP nor Mac shows up. How to reset the wifi dongle?
I’ve found with some phones you have to forget your local internet connection - because the dongle doesn’t provide an internet connection the phone disconnects part way through and re-connects to your normal wifi, try forgetting your normal wifi connection.
You can totally reset the dongle by unscrewing the collar at the top, pulling down to remove it - wait 15 seconds, then re-connect and screw the collar back up.
RP
I have been told by the commissioning engineer that the Foxcloud 2.4GHz dongle does not like some types of WiFi repeaters or Mesh type WiFi transponders. It simply does not see the SSID.
In my situation, my previous (Vodafone) router had to be set up with a dedicated 2.4GHz which then worked with Fox WiFi dongle. If left in default, the router provides one SSID with both 2.4 and 5GHz signals, which didn't work.
I also tried boosting the signal using the Tenda WiFi Mesh (2.4/5GHz signal set to Bridge mode) I have around the house. The Fox dongle couldn't see SSID - true to the commissioning engineer's comments.
Now I have another new router, I cannot get the dongle to pick up any signals that resembles my SSID - whether I dedicated a 2.4GHz Guest signal, use the Mesh, or default 2.4/5GHz SSID's from the router :(
I kept the SSID and PW the same from the 2.4GHz, hoping i didnt need to reconfigure the Fox dongle.
- Need to climb into the loft for one last ditch and yank the damn dongle for a power reset. Hopefully it will pick up new SSID's that I am broadcasting, rather than 17 other SSID's that are not mine.
suerayfl
I'm having similar problems - got new wifi 2 days ago and have followed all the instructions to connect to dongle and change the settings. It says it is successful but it is still offline, I've tried rebooting the inverter, taking out the dongle and re-seating. I even tried connecting back to the old router which was still live and that didn't work either!!! Why won't it connect?? Its very frustrating
suerayfl wrote: Sat Nov 30, 2024 2:25 pm I'm having similar problems - got new wifi 2 days ago and have followed all the instructions to connect to dongle and change the settings. It says it is successful but it is still offline, I've tried rebooting the inverter, taking out the dongle and re-seating. I even tried connecting back to the old router which was still live and that didn't work either!!! Why won't it connect?? Its very frustrating
It can be very frustrating when you are having problems with the datalogger - first thing to say is it will take at least 10 minutes after you have updated it for the website or apps to show it as on-line, secondly the Fox cloud has been quite unreliable this week and for many been showing their plant as off-line - also not helpful when you are trying to set it up. As far as I can tell the Fox cloud is currently working fine again.
When you say it is succesful what does the red light on the datalogger do ? - when disconnected it flashes red rapidly, when connected it settles down to a slow and steady red flash (once a second) with the occasional green pulse every 30 seconds - if it does that it thinks you are connected.
Will has posted a video above which guides you through the steps, but I have found that on some devices you have to forget their normal connection to the wifi as they will often abandon the connection to the dongle part way through and switch back to a connection that offers wifi.
sandvika
Lots of great information on this thread, thank you. When my inverter was installed over 4 years ago I had a basic ADSL broadband router, with a far better router behind it. I treated the ADSL router's WiFi as guest network & DMZ and the better router's WiFi as private home network. In the first instance I wanted the minimum number of dependencies so the installation engineer connected it to the guest network. 4 years later, I need to be more sophisticated with my scheduling than the built-in work models allow, so I want to control it locally using Home Assistant, which means bringing it onto the private home network. Thanks to the information here I have been able to achieve this.
My key take aways are:
1 - patience is a virtue. I got anxious about the cloud connection appearing to be disconnected far too soon, went into the loft and pulled out & replaced the data logger to reset it. I now believe this was completely unnecessary and actually delayed the cloud interface synchronisation.
2 - the configuration webpage only works when connected via the AP W-* network, although you can connect to it via your WiFi after configuring it, it then always gets stuck at the "Connecting . . . " . This is because the configuration webpage launches JavaScript which has the AP IP address 192.168.1.1 hard coded within it.
3 - due to (2) you are very vulnerable to losing access to the AP if someone network scanning knows that W-* means Fox ESS and thus also knows the default password. You need to change the password for your own protection!
Update 1: Six hours later, however, the dashboard is showing no generation for today, and is reporting the total for the month as zero, when it had been showing over 550 kWh. The cumulative totals for production and value appear to have regressed too, presumably by the same amount. The statistics bar charts are showing day, month and year correctly except for the hour I made the IP change, the day and the month, which are all showing zero for charge, discharge and total yield. I hope they sort themselves out.
Update 2: A day later, the dashboard is showing generation as if today is the first day of the month. The statistics bar charts are wrong for the hour on the day chart, the day on the month chart and the month on the year chart, reset to zero in each case for charge, discharge and total yield. Only the Feed-in Yield and Consumption are correct. I have no way of knowing if this is because I pulled out the data logger when I didn't see updates on the dashboard, but as this hasn't been reported before, I suspect it is. It implies that a single missing data point causes a "not-a-number" type result to the calculation rather than the better assumption of zero. I can at least calculate the month from the sum of the days and the missing day from the sum of the complete hours, so the data loss will only affect the dashboard, not my ROI calculations.
Life is about to become more interesting. I've just had a heat pump installed and now intend to add more solar panels and another inverter and more battery to minimise its running costs. The heat pump draws 5.5 kW when running in hot water boost mode which is bad news with my Fox ESS 5.0 kW inverter.
Sandvika (she/her)
H1-5.0-E
BMS V1
3 x HV2600 V1
16 x Perlight PLM-345M(B)-66
