Prior to app and firmware updates O was charging the Battery and my EV at the same time at cheap rates. Since updates the Battery is not charging until EV at 100%. Any idea what settings have changed to fix?
Your inverter is seeing the load of the car charger and limiting its own input power.
Check your import limit settings, some have found these changed following firmware updates.
Set this based on the capacity of your incoming supply - for 240v with 80A fuse then 19,000W is a safe value.
Manager(ARM):1.69
Master:1.51
BMS:1.012
Manager(ARM):1.69
Master:1.51
BMS:1.012
You can check your Import limits on Inverter and also your battery. Worth taking a picture or writing down your values.
I see nrb501 posted same, but now you have video to watch
You can also just make a quick picture of your Quick Settings page in your Fox Cloud 2.0 App (new version)
Find and take a picture of your Import/Export page here
Thanks. Prior I could also set so the EV would not drain the battery with MIN On SOC at 80 or 90% while charging both. Now this is not an option if I set to Charge at same time will it just drain the battery or charge both regardless of Battery %?
If you show your Import values in your Quick Settings in the App, that could solve your problem quickly.
There are bugs in some settings in the App that are reversed from what you see on your screen, that does not help us all.
