Hello, I just watched Will's very informative video on YouTube about the ability to update software via the v2 Fox app. Both my inverter and battery are behind the latest versions - my solar installer refused to do aftercare, and Fox firstly stopped responding to my requests via Support in the app, and now have actively removed the option 'Support' from the app (it flashes up briefly when loading the Contact Us page, but disappears - if anyone has a solution to this, please let me know).
I have just updated my app to the newest version, but none of the options shown in the video appear. On the Inverter or Battery tab, I have no graphic telling me there is a new update waiting, then when I click in on the serial number, under Versions I just see the firmware values alone. No red dot, no wording saying they are up to date.
I have an H1-3.7-E-G2 inverter, and EP5 battery.
Inverter versions are Master 1.33, Slave 1.02, Manager 1.49
Battery version 1.006
How can I get the ability to update my own software? I currently have no way to contact Fox at all, and the brand new app update hasn't given me this feature. Thanks
EP5 5.18kWh battery
EP5 5.18kWh battery
It’s only just been released, in fact I only found out about this morning as it was due to be released on Monday and got released early
- you do need the latest app downloaded but from what i’m hearing the facility is only slowly rolling out across the various inverters, dataloggers, batteries etc.. (my gen1 H1 is not showing the feature yet).
If anyone wants to look at the video you’ll find it here https://youtu.be/dJ4jQ_zyako?si=qznUVTTVTv4b5fPz
Thanks Dave - didn't even clock how recently the video had been uploaded, that's my fault! I'll check back in a while for another app update.
EP5 5.18kWh battery
EP5 5.18kWh battery
Current Android version is v2.1.79 (24hrs old)
Current iPhone version is v2.1.92 (3hrs old)
I have an Android phone and am not seeing it yet, hopefully they bake an nice APK for us soon.
Currently I believe only the H1 Gen2 has updates available from the app (in theory anyway).
I seem to recall that the H1 Gen1 won't be supported due to hardware limitations.
I asked about the KH and Fox said that support for updating the KH is coming soon.
They also plan to support updates for the datalogger and batteries, but that's more of a longer term thing (so people wanting the 5 second updates might still need to get the datalogger updated via their installer etc).
Cheers for the additional info, no rush for me to get upgrades currently, just be nice to see things coming together in Q1 2026.
It would sure be nice to upgrade all of the items at some stage, but happy for any new progress.
Got the option to upgrade on the inverter today
Master and Slave both updated.
Process took about 20 mins.
Did not give the option to upgrade individually, once you started the process each one went through rebooting the inverter each time.
All looks good once finished and all previous settings to mode scheduler and battery warmup retained.
For what’s a major culture change for FOX, looking forward to further user control in the coming months.
Good job done by all.
Was out with my mate having a beer this evening, and his app showed updates for both his inverter and Datalogger, which all installed OK. He can now see 5sec updates.
His battery is behind and no update for that.
So good news, things are moving forward.
This is very postive stuff, and will reduce the support tickets by no end.
Have now had the Android app update, inverter versions updating as we speak. As someone noted earlier, doesn't seem to be for the batteries at the moment, just the inverter. Still, a great update for us.
EP5 5.18kWh battery
EP5 5.18kWh battery
I only just got the update to v2.2.0 on Android, it looks very nice, but the FW versions do not show installed vs. available for my Inverter.
For example, my KH7 shows
Master 1.58 only, not as
Master 1.58 (1.58)
Not too worried, as they are current versions, but I hope they fix it in a future update.
Maybe you can tell us what version you have installed and a picture of your Inverter screen?
As far as I know, support for updates on the KH is still to arrive, it's live on the H1 G2
Aha, well then I have to wait for a bitWyndStryke wrote: ↑Fri Feb 06, 2026 1:40 pm As far as I know, support for updates on the KH is still to arrive, it's live on the H1 G2
Thanks again for letting me know.
I was pleased with the new app update, in Quick settings you can change the Import/Export values now.
Something new to adjust (mine was set to 14500W, upped to 18400 W to see how it does with the EV.
But not the newer H1-x.xx-E-G2-WL yet, it would appear...WyndStryke wrote: ↑Fri Feb 06, 2026 1:40 pm As far as I know, support for updates on the KH is still to arrive, it's live on the H1 G2
Fox ESS H1-6.0-E-G2-WL Firmware - Master: 1.55 Slave: 1.04 Manager: 1.41 Datalogger (internal wifi) : 2.09
Fox ESS ESC 2900-H4 Cube Battery - Master plus 3 Slaves - All V2 - 11.52kWh Firmware - Master: 2.015 All Slaves : 1.150
Fox ESS Firmware updates applied June 2026
Octopus Intelligent Go tariff
That has it's own firmware compared to the original, but additionally, the ability to update firmware is also rolling out slowly, rather than to everyone at once.
* Firmware required for 5-second updates https://fox-ess.tech/5-second-live-ener ... d-devices/
* In-app firmware updates https://fox-ess.tech/inverter-firmware- ... cloud-app/
Current firmware is (H1-6.0-E-G2-WL) Master: 1.51 Slave: 1.04 Manager: 1.35 Datalogger (internal wifi) : 2.08 - 5 second updates working great already….
Is there any information available if user updateable firmware through the app will be available for H3-Pro inverters? I am currently on 1.68/1.06/1.22 (Master/Slave/Manager) with a W6 datalogger (v1.05).
Some things might require Fox to update currently, the other things may all be added in time.
It might be just as well to get Fox to do an update on all your items now, and if they add support in the future for your H3 Pro, then you can DIY.
2.2.1 on android allows KH to be updated
For timings, datalogger updated first at about 8:05, but does not show in the modbus logs. Inverter update process started around 8:10-8:15. So around 35-45 minutes in total.
Interestingly the app shows 1.02 as the new slave version, but modbus shows 1.01
13 February 2026
Inverter State changed to On Grid 08:46:03 - 32 minutes ago
Inverter State changed to Checking 08:44:38 - 34 minutes ago
Connection Status changed to Connected 08:44:32 - 34 minutes ago
Inverter State changed to Waiting 08:44:32 - 34 minutes ago
Version: Slave changed to 1.01 08:44:32 - 34 minutes ago
Version: Master changed to 1.60 08:44:32 - 34 minutes ago
Version: Manager changed to 1.58 08:44:32 - 34 minutes ago
Inverter State became unavailable 08:41:49 - 36 minutes ago
Version: Slave became unavailable 08:41:49 - 36 minutes ago
Version: Master became unavailable 08:41:49 - 36 minutes ago
Version: Manager became unavailable 08:41:49 - 36 minutes ago
Connection Status changed to Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 43; slave: 247 from tcp://192.168.68.200:502: Modbus Error: [Input/Output] No Response received from the remote slave/Unable to decode response 08:41:49 - 36 minutes ago
Inverter State changed to On Grid 08:37:03 - 41 minutes ago
Inverter State changed to Checking 08:35:43 - 42 minutes ago
Inverter State changed to Waiting 08:35:28 - 43 minutes ago
Connection Status changed to Connected 08:35:27 - 43 minutes ago
Inverter State changed to On Grid 08:35:27 - 43 minutes ago
Version: Slave changed to 1.01 08:35:27 - 43 minutes ago
Version: Master changed to 1.60 08:35:27 - 43 minutes ago
Version: Manager changed to 1.58 08:35:27 - 43 minutes ago
Inverter State became unavailable 08:34:54 - 43 minutes ago
Version: Slave became unavailable 08:34:54 - 43 minutes ago
Version: Master became unavailable 08:34:54 - 43 minutes ago
Version: Manager became unavailable 08:34:54 - 43 minutes ago
08:34:54 - 43 minutes ago Inverter State changed to On Grid
08:28:13 - 50 minutes ago Inverter State changed to Checking
08:26:48 - 51 minutes ago Inverter State changed to Waiting
08:26:43 - 51 minutes ago Inverter State became unknown
08:26:40 - 51 minutes ago 12 February 2026
Inverter State changed to On Grid 23:05:01 - 10 hours ago
Version: Slave changed to 1.01 23:05:01 - 10 hours ago
Version: Master changed to 1.41 23:05:01 - 10 hours ago
Version: Manager changed to 1.37 23:05:01 - 10 hours ago
Great news,
As always my Google Play store likes to live in the past for me, and getting the update is delayed for some reason.
So still stuck on 2.2.0.
I had this when I was updated to 1.02, reboot your HA and it should then read the value correctly.WyndStryke wrote: ↑Fri Feb 13, 2026 7:58 am Interestingly the app shows 1.02 as the new slave version, but modbus shows 1.01
Hey WyndStryke,
I checked at time of your post, no App update.
Drank some coffee and checked it 30 mins later and 2.2.1 landed.
Manager updated from 1.58 to 1.60
