Hi Guys i have a KH10 inverter iwth 42kw batteries was wondering if there is a new firmware and where i can download it.
Version_Master:
1.52
Version_Slave:
1.02
Version_ARM:
1.52
The spreadsheet Will has posted is usually very up to date viewtopic.php?p=8069#p8069
Version_Master: 1.52 -> 1.55
Version_Slave: 1.02 -> 1.02
Version_ARM: 1.52 -> 1.58
Edit: Dave beat me to it, and you should ask your installer to push firmware updates, if they don't then you can contact Fox Support via email https://www.fox-ess.com/contact-us
thanks guys was hoping i can do it myself via usb. i have sent a request to fox via the link you provided.
Hopefully they reply soon. Thanks again.
Well hopefully they do reply quickly, 2-3 days in some cases.
Check spam folder often, and if you haven't, have your inverter serial number ready.
After I complained to Fox that battery warmup was not working properly, my KH10 Master firmware was updated to 1.58 today (same version as Manager). It's cold tonight so I will find out later if this makes any difference! When cold, the system seems very reluctant to use solar or stored energy (even when SOC>40%) and spontaneously starts to charge the battery from grid when its temperature falls to 3°C, which I can't control. I have EP12 batteries (with heater) but would prefer not to warm from grid at an expensive time of day.
I received a partial update today. Manager went to 1.58 but master is still 1.52. Lets see what happens tomorrow.
