New EP11 battery - Total Discharged Energy
I have just had a new EP11 10Kwh battery installed. The app is showing that the Total Discharged Energy is 936.9kWh. Surely if the battery is new this number should be close to zero? Am I being stupid?
EG
Re: New EP11 battery - Total Discharged Energy
Mine did indeed start close-to zero. That's interesting. Does the Total Charged Energy roughly match?
Total Charged Energy is 1.14MWh...so close.
EG
I would perhaps send off a ticket to Fox Support, as they could check perhaps if the battery was registered to a previous "Plant" and explain the total kWh used is high.
Thanks. My installer is going to do exactly that.
EG
How many battery cycles does the app display ?
107 battery cycles.....
EG
Would certainly suggest it wasn’t new out of the box then
EarlGrey wrote: Thu Dec 25, 2025 10:18 pm 107 battery cycles.....
EG
For rough guidance.
In 10 months, I have 197 cycles (1.92 MWh)
Be interesting to hear what your installer/Fox have to say on the values you have.
Good luck with getting answers.
Thanks! I'll let you know....
EG
