I have just had a new EP11 10Kwh battery installed. The app is showing that the Total Discharged Energy is 936.9kWh. Surely if the battery is new this number should be close to zero? Am I being stupid?
EG
Mine did indeed start close-to zero. That's interesting. Does the Total Charged Energy roughly match?
I would perhaps send off a ticket to Fox Support, as they could check perhaps if the battery was registered to a previous "Plant" and explain the total kWh used is high.
Would certainly suggest it wasn’t new out of the box then
