Battery not showing up on fox ess 2.0 app
Just had my electrician finish installation for fox invertor and battery.
Battery isn't showing on the app, do I need to add it somehow?
Thank you
Re: Battery not showing up on fox ess 2.0 app
Your battery should show up if it is connected and working, if it doesn't show on the app then it isn't communicating properly with your inverter.
Leave it an hour or two as i've heard a few reports of Fox cloud problems this morning, if it's still not showing later - call your installer back.
Hi I have the same problem batteries not showing on app but are working, data is available? Did your problem get fixed?
