Checking Firmware
Posted: Tue Jun 11, 2024 1:02 am
by RokaBoi
Hello, how do I check for latest firmware for inverter and batteries? Thank you.
Re: Checking Firmware
Posted: Tue Jun 11, 2024 8:52 am
You can't check the latest yourself, but you can check what you have installed from the inverter panel select 'About, Inv Ver' and it will show you the Inverter Master, Slave, Master versions and 'About, Bat Ver' will show you the Master / Slave versions for the batteries.
If let me have your inverter type and series i.e. H1 (G2), KH etc.. and your battery type and versions i.e. HV2600 V2, ECS2900 V1 etc.. I can look up the latest versions
Posted: Tue Jun 11, 2024 11:21 am
by RokaBoi
Inverter H1-6.0-E-G2
Master 1.18
Slaver 1.02
ARM 1.37
Battery ECS4300
Master 60KM43202BTG015
Slaver 60KM43202BTG015
Slaver 60KS43202BYB056
BMS 1.005
Posted: Tue Jun 11, 2024 12:01 pm
RokaBoi wrote: ↑Tue Jun 11, 2024 11:21 am
Master latest is 1.22
Your Slave & ARM are up to date
Battery ECS4300
BMS Master latest is 1.014
Slave latest is 1.11
Posted: Tue Jun 11, 2024 10:06 pm
by RokaBoi
Thank you.
Posted: Mon Jun 24, 2024 8:59 am
by jaal2001
Dave Foster wrote: ↑Tue Jun 11, 2024 8:52 am If let me have your inverter type and series i.e. H1 (G2), KH etc.. and your battery type and versions i.e. HV2600 V2, ECS2900 V1 etc.. I can look up the latest versions
Hi Dave,
would be great if you could also check for mine:
H3-10.0-E
Battery is Energy Cube CM2900 V2.0
Current reported versions are:
Version: Manager 1.56
Version: Master 1.64
Version: Slave 1.03
Jan
Posted: Mon Jun 24, 2024 9:47 am
jaal2001 wrote: ↑Mon Jun 24, 2024 8:59 am Hi Dave,
H3-10.0-E
Version: Slave 1.03
Jan
Sure, no problem, latest versions -
Manager 1.78
Master 1.98
Slave 1.03
ECS2900
Master (BCU) 1.014
Slave (BMU) 1.11
I believe the latest version introduces the scheduler to H3 and allows timed force discharge / charge, work mode and minsoc changes
Posted: Mon Jun 24, 2024 12:02 pm
by jaal2001
Thanks!
