You can't check the latest yourself, but you can check what you have installed from the inverter panel select 'About, Inv Ver' and it will show you the Inverter Master, Slave, Master versions and 'About, Bat Ver' will show you the Master / Slave versions for the batteries.
If let me have your inverter type and series i.e. H1 (G2), KH etc.. and your battery type and versions i.e. HV2600 V2, ECS2900 V1 etc.. I can look up the latest versions
Inverter H1-6.0-E-G2
Master 1.18
Slaver 1.02
ARM 1.37
Battery ECS4300
Master 60KM43202BTG015
Slaver 60KM43202BTG015
Slaver 60KS43202BYB056
BMS 1.005
Master 1.18
Slaver 1.02
ARM 1.37
Battery ECS4300
BMS 1.005
Hi Dave,Dave Foster wrote: ↑Tue Jun 11, 2024 8:52 am If let me have your inverter type and series i.e. H1 (G2), KH etc.. and your battery type and versions i.e. HV2600 V2, ECS2900 V1 etc.. I can look up the latest versions
would be great if you could also check for mine:
H3-10.0-E
Battery is Energy Cube CM2900 V2.0
Current reported versions are:
Version: Manager 1.56
Version: Master 1.64
Version: Slave 1.03
Jan
Sure, no problem, latest versions -
Manager 1.78
Master 1.98
Slave 1.03
ECS2900
Master (BCU) 1.014
Slave (BMU) 1.11
I believe the latest version introduces the scheduler to H3 and allows timed force discharge / charge, work mode and minsoc changes
