Checking Firmware
You can't check the latest yourself, but you can check what you have installed from the inverter panel select 'About, Inv Ver' and it will show you the Inverter Master, Slave, Master versions and 'About, Bat Ver' will show you the Master / Slave versions for the batteries.
If let me have your inverter type and series i.e. H1 (G2), KH etc.. and your battery type and versions i.e. HV2600 V2, ECS2900 V1 etc.. I can look up the latest versions
Inverter H1-6.0-E-G2
Master latest is 1.22
Your Slave & ARM are up to date
Battery ECS4300
BMS Master latest is 1.014
Slave latest is 1.11
Hi Dave,Dave Foster wrote: Tue Jun 11, 2024 8:52 am If let me have your inverter type and series i.e. H1 (G2), KH etc.. and your battery type and versions i.e. HV2600 V2, ECS2900 V1 etc.. I can look up the latest versions
would be great if you could also check for mine:
H3-10.0-E
Battery is Energy Cube CM2900 V2.0
Current reported versions are:
Version: Manager 1.56
Version: Master 1.64
Version: Slave 1.03
Jan
Sure, no problem, latest versions -jaal2001 wrote: Mon Jun 24, 2024 8:59 am Hi Dave,
H3-10.0-E
Version: Slave 1.03
Jan
Manager 1.78
Master 1.98
Slave 1.03
ECS2900
Master (BCU) 1.014
Slave (BMU) 1.11
I believe the latest version introduces the scheduler to H3 and allows timed force discharge / charge, work mode and minsoc changes
