I'm trying to get readings off my F3000 inverter. It sounds like this may not actually be supported, although it's hard to find any accurate information on this. Has anyone here succeeded in getting it to talk and appear in HA?
Thanks,
Ben
It's not supported as such (other than by cloud which you could use the foxess cloud integration for https://github.com/macxq/foxess-ha [which is relatively easy to do] )
But have a read of this thread (viewtopic.php?t=740)
if you are electronically minded and fancy a diy project some information can be found direct from the inverter.
