Hi.
I had a foxess system installed a couple of weeks ago and today I got my smart meter installed.
My system is a 12kw solar, kh10 and 40 kw battery.
From the app, I have been generating a lot more power than I need so have been exporting.
Today once the smart meter was installed after a few hours I noticed that the INL 1 reading was 17kw (happened to coincide with 17kw that my system says I exported) and the EHL 1 reading was 0.08kw (coinciding with how much i used of the grid).
Is it possible the smart meter has been wired backwards? It looks like its counting what i and exporting as if i was importing?
I rang the electricity company and they advised i have to wait 10 days for the system to register to check but im worried if it is flipped ill get charged for my exports?
Thanks!
Who is your energy supplier?
I would be surprised if a meter was wired backwards.
Origin is the supplier.MaterialBarracuda48 wrote: ↑Mon Mar 16, 2026 8:31 am Who is your energy supplier?
Could something else be wired wrong given those numbers?
Do you have an online way to view submitted meter readings online?
Just to know they could be a few days behind real-time if you can check.
Looking at the meter will show you if the meter has been physically wired correctly, it is a standard wiring layout so there should be no reason for it being wrong.
The incoming supply from the DNO cut-out (main fuse) should be on the left hand pair of terminals and the feed to your distribution board(s) on the right hand pairs, the sequence left-right being:
Live in
Neutral in
Neutral out
Live out
Also what model of meter is it.
If in doubt, post a photo.
Live in
Neutral in
Neutral out
Live out
Manager(ARM):1.78
Master:1.59
BMS:1.013
Manager(ARM):1.78
Master:1.59
BMS:1.013
No not yet. They have said i need to wait 10 days for it to be available online hence my concern where the numbers will be in 10 days.MaterialBarracuda48 wrote: ↑Mon Mar 16, 2026 10:02 am Do you have an online way to view submitted meter readings online?
Thanks. This is the model of the smart meter and the instructions im following about what each code meansnrb501 wrote: ↑Mon Mar 16, 2026 3:56 pm Looking at the meter will show you if the meter has been physically wired correctly, it is a standard wiring layout so there should be no reason for it being wrong.
Live in
Neutral in
Neutral out
Live out
https://www.originenergy.com.au/content ... r_2016.pdf
The other possibility I can think of is your solar CT clamp is backwards.
You said you export 17kWh, was this reading from FoxCloud2.0 App?
Do you have some pictures from the App to share?
I should have guessed you were in Aus, the EDMI meter you have is different to the ones we have fitted here in the UK. That said, I'd be surprised if the connection layout is different but you never know....
It certainly seems like your meter is reading export as import but the unknown at the moment is how Origin's back-end systems will interpret the data, it certainly does seem wrong though. The only thing I would suggest is make a noise now and get your concern registered, although that may take some patience to get past the first line of call handlers.
If you have an independent ombudsman then contacting them may be an avenue to go down if Origin are being "special".
Best of luck
Best of luck
Manager(ARM):1.78
Master:1.59
BMS:1.013
Manager(ARM):1.78
Master:1.59
BMS:1.013
Just wondering if you can pull up your meter reads online yet?
https://www.originenergy.com.au/help-su ... -gas-usage
In the UK, they can be a few days before they update, could be same for you also.
Yes this is from the app.MaterialBarracuda48 wrote: ↑Mon Mar 16, 2026 7:43 pm The other possibility I can think of is your solar CT clamp is backwards.
I am worried about the ct clamp as I had some issues with it during the first install.
I've attached an image shortly after I read the smart meter (so was more that 17kWh)
No not yetMaterialBarracuda48 wrote: ↑Mon Mar 16, 2026 8:08 pm Just wondering if you can pull up your meter reads online yet?
You should be checking when the Sun comes up no doubt, and chase like @nrb501 suggests also.
Best of luck
Best of luck
I just found a hardware reference guide for your meter https://www.camax.co.uk/downloads/EDMI- ... sion-M.pdf on the last page there is the following gem which is likely the source of all the confusion:
Export is exporting or delivering energy to the customer‟s load, import is importing or
receiving energy from the customer. All conventions are from the point of view of the
supply authority.
Manager(ARM):1.78
Master:1.59
BMS:1.013
Manager(ARM):1.78
Master:1.59
BMS:1.013
Thanks so much.. .this was doing my head in!!nrb501 wrote: ↑Mon Mar 16, 2026 10:06 pm I just found a hardware reference guide for your meter https://www.camax.co.uk/downloads/EDMI- ... sion-M.pdf on the last page there is the following gem which is likely the source of all the confusion:Export is exporting or delivering energy to the customer‟s load, import is importing or
supply authority.
So it actually all looks OK then despite my concerns!?
Hopefully that is the case, only when you get billing data from Origin will prove it though.
Manager(ARM):1.78
Master:1.59
BMS:1.013
Manager(ARM):1.78
Master:1.59
BMS:1.013
So I think my meter is finally online (im able to select solar plans online from. Today). That said, logging onto the origin app shows 0kw usage and 0kw export. Does anyone know if this takes additional time to start working?
Called and spoke to origin, they have no idea what they are doing, very frustrating.
Thanks. I think this was referencing in the app it will only show results for previous day, not current day. Im now 2 day later ans still shows 0kw for everything.MaterialBarracuda48 wrote: ↑Fri Mar 20, 2026 9:56 am https://www.originenergy.com.au/help-su ... data-delay
Claims 24-48hrs delay behind realtime
Guess ill need to tempt calling origin again.
You would like to think a new meter would be registered quickly, perhaps they have not associated the meter SN with your account yet.
Best of luck with chasing this down.
