Hi all.
I've got the heated EP11 battery with KH10.5 inverter. The battery is the heated model and since updating firmware I can set warmup periods and temperatures. But I can't see any of that data from the Home assistant modbus integration. Does anyone know if it should be there and I need to do something or if there is a reason it's not showing?
Battery version: 1.006
Inverter Version_Master: 1.47
Inverter Version_Slave: 1.02
Inverter Version_ARM: 1.45
Thanks for any help.
Alan
