Can't find battery heating data through modbus
Hi all.
I've got the heated EP11 battery with KH10.5 inverter. The battery is the heated model and since updating firmware I can set warmup periods and temperatures. But I can't see any of that data from the Home assistant modbus integration. Does anyone know if it should be there and I need to do something or if there is a reason it's not showing?
Battery version: 1.006
Inverter Version_Master: 1.47
Inverter Version_Slave: 1.02
Inverter Version_ARM: 1.45
Thanks for any help.
Alan
Re: Can't find battery heating data through modbus
Sadly as of yet the battery heating function registers have not been exposed over modbus and the only way to set it is via the app.
Thanks for the reply. Let's hope that gets updated soon.
