Different battery temperatures in FoxV2 compared to Energy Stats.
Hi everyone,
FoxV2 shows my battery temperature as 26.8'C currently.
Energy Stats is showing 40.2'C.
Are they measuring different things?
Re: Different battery temperatures in FoxV2 compared to Energy Stats.
Energy stats uses the battery value from the openapi, which is actually the bms battery value and tends to be a lot higher than the battery cells temps.
Fox ESS v2 is reporting the correct battery temp known as BMS Cell Temp Low
Thanks, Will.
